Question about Maytag Neptune Washer
My washing machine starts and then goes off after
My maytag neptune front loading washing machine starts and then goes off after a few minutes. it's been getting louder the last few weeks, and now it just keeps going off after we start it. the last time it worked for a while it left water in the drum before it shut off, so it got that far in the washing process i guess... any ideas?
    Problem Solver:
  • 6 Answers
I'm not sure which model that you have, but I will venture to guess that it is a Maytag MAH5500BWW. If that is the model you have, I would say that your problem is with the motor/motor control panel, this has been re-engineered with a replacement. You can check all functions of your machine by placing it in service mode.To do this, turn machine on then press the delicates and heavy soil key for 3 seconds, then press spin to do a quick spin test. If it doesn't spin, then you may have that faulty motor design. In your machine behind the touchpanel on top there should be a tech sheet for your machine which tells you how to do this and how to check every operation of the machine. Replacing motor and control board is a very easy fix and if you contact Maytag (now whirlpool) they will give you a very nice price on all replacement parts for your machine. Hope its not the bearing!
Posted on Feb 15, 2010
  • Suz_3 Sep 03, 2010
    You are awesome! My machine got stuck because I overloaded it. I emptied it out and then tried to start it again but every time it would just keep stopping and unlocking the door! I looked and looked through the internet and couldn't find a solution ... waited for a VERY long time for Maytag Customer Services ... while I was STILL waiting ... your solution above ... ie ... just doing a quick spin test ... emptied my machine and now I'm doing another load! I was nearly done with the quick spin test when I contacted Maytag and I fixed it all while they were taking down my model and serial number!! I said don't worry I've fixed it. They said just be careful and put something you don't need for a while since they won't be able to come out until Wed or Thur next week (its Friday). Thanks again!!! Hope you get loads of votes for helping me with my load!
  • juanmanuelst Oct 04, 2010
    Marvollous comments. Very helpful. Thanks
  • 1,531 Answers
You need to check the drain pump and look to see if there is anything that might be caught in the pump.
if there is still water in the pump you can use a wet dry shop vac and attach it to the end of the drain hose and remove the water.
then remove the hoses from the pump if you do not find anything in the pump look in the hose that comes from the bottom of the tub to the drain hose and look for something there
Posted on Feb 07, 2010
  • 530 Answers
When you spin the drum by hand does it sound grindy?
can you lift the basket up and down
is there play?
sounds like to me you have a bad bearing
about an $800 repair
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
I have a top loading Maytag Neptune TL that will not drain. When you start the machine it runs for a few minutes & then shuts off and the time on the screen freezes. I think there is possibly an issue...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load washer says control lock and wont start and buttons wont work
unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
Jun 09, 2009 | Maytag Neptune MAH6700A Front Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune washer 9 min
check your pump for obstructions, including the filter
Apr 22, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
349 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
