Question about Hobart H600 Stand Mixer
Dough Hook Stops moveing under heavy load
Dough hook stops moving as the load gets heavier and heavier, eventually stopping althought the motor continues to operate without any problem. No noise or stress sounds coming from the motor, the dough hook just stops moving. Do these units have a slip clutch or some other mechanism to adjust the torque it can handle?
  • Sorsa Feb 22, 2008
    Is that difficult to repair and how long shold it take a Hobart technician to fix.?
  • Sorsa Feb 27, 2008
    H600T I think we found the problem with a broken key.
  • 640 Answers
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Posted on Feb 22, 2008
  • 2 more comments
  • anthony james
    anthony james Feb 23, 2008
    Does it run in any speeds?If it doesnt run in any speed it may be the sacraficial worm gear---11-2 hour labor plus parts.If it runs in some gears its probably a sheared key,the key is $5 bucks plus labor about 1 hour.Worst case senario if you switch gears and hear a noticable noise it may be a broken shaft/gears and this could be well over 1000 bucks to repair.Without seeing the mixer im giving you the problems that ive seen.Depending on the tech and how much he knows will determine the labor price.If you can give me some details about the mixer and i would need to ask you ? in detail,i could step you thru in order to repair it yourself but it is tedious.It would take me in ordinary time to troubleshoot and repair in 2-2-1/2 hours tops.
  • anthony james
    anthony james Feb 27, 2008
    what is your model?
  • anthony james
    What shaft was the key on?
  • Todd Hon
    Todd Hon Mar 22, 2013
    Yes what shaft was the broken key on because we have the same problem!
Broken gear
Refer this problem directly to Hamilton Beach as the primary source of the parts.
Dec 12, 2013 | Hamilton Beach Eclectrics All-Metal Stand...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
I can hear the motor running, but the attachment does not move.
Sounds like what happened to my wife's mixer. There is one nylon gear in the drive assembly that is designed to break if too much load is put on the mixer. Like what can happen with dough or butter that is too hard/frozen. That is designed to save rest of the mixer. Sounds like you need to replace the KitchenAid Mixer Worm Drive and Pinion Gear Assembly. In our case, it was not the nylon gear that broke, but a small pin that is this gear assembly. By getting the assembly & not just the nylon gear, you cover more of your bases. I found a video on line that walks you through replacing the part. I also bought the part online. The assembly part, including shipping cost me $12.95.
Hope this helps.
Nov 30, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Mar 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Bosch aluminum dough hook has black coating
the problem is where the pin on the beater shaft locks into the hook may be wearing down or the hook itself.when you put the hook on see if you get alot of play in the hook (wiggle it and if it feels really loose its worn).its still safe to use but eventually (and this may be quite sometime) the pin may break off the beater shaft.you would then have to replace the pin and hook.
Jan 27, 2008 | Bosch 700 Watts MUM6622 Universal Series...
Hobart H600 Stand Mixer Logo
665 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
