Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer is too cold, refrigerator does not work
I have a side by side refrigerator. The freezer is too cold, refrigerator barely blows out cold air.
  • 311 Answers
The problem is with your defrost system. If you remove the back panel of the freezer you will probably find a solid block of frost/ice. This restricts your airflow across the evap coils not allowing air to circulate to the ref side. It could be a problem with your defrost heater, termination, or defrost control. Your termination will be located at the top of the evaporator coils when you remove the back panel you can usually do a visual inspection of the component to see if it looks "popped out or swollen with ice" the heater can be tested for continuity. If the heater ohms out ok then the easiest thing to do would be replace the defrost control and termination. You will need to let the evap coils completely thaw out with a heat gun or by turning the unit off w/ the doors open for 24 hrs before plugging it back in after replacing components.
Also make sure your evaporator fan motor is running in the freezer to pull the cold air over to the fresh food side. If its not running then you probably have a bad evaporator fan motor.
Let me know if this helps _MJ_
Posted on Feb 07, 2010
I can not locate the fan that blows to lower part of the refrigerator
In most older reefers, the fan in the back of the freezer does the entire job. It blows cold air through a duct that leads to the ******. If you have no cold air in the ******, but your freezer is still cold...but barely, your fan is shot.
May 02, 2012 | Kenmore 18.2 cu. ft. Top Freezer...
Maytag MSD2651HEW refrigerator not cool, freezer works fine. If open both doors, feel cold air blowing in refrigerator side
try keeping the freezer door shut while felling for cold air blowing over to refrigerator side..if so problem lies in the thermostat...its not sensing the correct temp for the fridge side and closing the damper too early...also check to see if there is frost built up on the back wall of the freezer section if thats the case then you are at the begining stages of a defrost issue and soon no cold air will blow over to fridge side..let me know what you find
Mar 13, 2012 | Maytag MZD2766GES Side by Side...
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Freezer works fine but fridge side is barely cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Jenn-Air JCD2389G Side by Side...
Refrigerator side is not cold
Sounds like a problem with the damper control. Some fridges gets humid air causing frost on the damper and causing this to fail. It may need to be replaced or check if the damper (the vent were the cold air comes out from the freezer) is open.
Jun 07, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Refrigerator not working but freezer is
You have two vents between the freezer and fridge. The one the cold air from the freezer comes through(blown by the fan) and the other vent is a return vent back to the freezer. On a side/side they're at the top and bottom. It sounds like the bottom one may be blocked by food or frosted closed by ice.
Aug 22, 2009 | Refrigerators
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
No cold air coming into the fridg
iF YOUR REFRIGERATOR SETTING IS HIGH, YOU NEED TO LOWER THE SETTING IN ORDER TO GET IT COLDER.
If you still have no air flow, there is a fan that blows cold air from the freezer to the refrigerator. The motor could be burned out.
Sqiudo
Dec 15, 2008 | Jenn-Air JSD2789GES Side by Side...
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets cold...fan blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
108 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
