Question about HP Photosmart M22 Digital Camera
It was dropped.. and now when i open the lens window It comes to a red screen saying I must restart my camera.. Anyone know how this is done?
  • 1 more comment
  • KB33 Feb 22, 2008
    I removed the batteries and memory card as you mentioned.. waited then tried and i still get the same message "Camera has experienced an error. 000000C8-8BE7-586-053 Please reset your camera or consult User's Manual.
  • soag4real May 16, 2008
    i removed the batteries, memory card and leave it for a while but it still show the same code (000000c8-8BE7-586-053).
  • Anonymous Mar 05, 2009
    when i tried the whole list of things to try to fix it, they didnt work.
    i need some help please
I still can't solve my problem with my camera.
the screen still displays a red color
Posted on Mar 29, 2009
    Problem Solver:
  • 18 Answers
From the HP website:
Please, perform a camera hard reset. To do so, follow the steps below:
  1. Turn off the camera.
  2. Remove any memory card installed.
  3. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
  4. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
  5. Verify if the camera works without an optional memory card.
Hope that helps.
Posted on Feb 21, 2008
  • Loren Undseth Feb 22, 2008
    Did you try restarting it without the memory card in it?
    It's too bad that didn't take care of the problem for you.
    This is also from the HP website:
    If the error message still appears after performing the camera hard reset, please click
    contact hp
    on this page for more
    support.
    CAUSE:
    The issue is caused by the
    Focus Home Sensor
    falling out of its position.
Error message it says to please reset I would but it will not let me get off the red error screen,please help
Simple....remove the card and battery....press all the buttons....leave it alone for 10 minutes....insert the battery and turn it on. If it turns on, reinsert the card. Enjoy!
Jun 15, 2011 | HP Photosmart M22 Digital Camera
I dropped my camera and now the lense wont retract all the way. a red screen pops up and says "Lens error, try turning the camera off then on again' the lense wont come out, what do i do?
There can be a mechanical break or a lens mounting break due to the fall and so the camera must be opened out to reset the lens hood.
You will need some experience to remove carefully and checck the drive for the dislocation of the motor control.
It can be a visual indicatiion to the fault if looked in and can be removed ,reset or the brokedn part glued into the mount.
Oct 01, 2010 | HP PhotoSmart M437 Digital Camera
Dropped camera now lens wont close. It says lens
Remove the batteries and insert new batteries . Sometimes this may work but in your case the lens is stuck inside, or it will have been damaged . Nothing can be done other than taking to service center to get it repaired .
Hope this helps .
Dec 16, 2009 | Canon Cameras
"Lens error, restart camera"
change the lens cover and change the battery please vote
Nov 04, 2009 | Canon PowerShot A1100 IS Digital Camera
Lens won't open, & it says lens error, restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
Camera was dropped now it is saying that there is a lense error HELP!
My camera was dropped and now the lens will only detract half way. It says lens error and restart camera. It is a Cannon Power Shot SD1100 IS. Thanks.
Jul 13, 2009 | HP Photosmart M425 Digital Camera
My camera wont turn on.
ur lens strip is broken by using in out lens dont use zoom it crecks ur belt. now send for service
Jun 18, 2009 | HP Photosmart M22 Digital Camera
Lens problem
you should have dropped your cam down to the floor or you should have forcibly tried to put your lens inside when the servomotor lens tried to bring the lens out..take your camera to the nearest service centre..you should not try to open the cam since the parts used in it are very small and even a slight modification might be responsible for huge change in the calibration.so my best advice is to take it to the nearest service centre available..
May 26, 2009 | Canon Powershot A1000IS 10MP Digital...
HP Photosmart M22 Digital Camera Logo
257 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
