Question about D-Link Xtreme N DIR-655 Wireless Router
We just bought a new emachine, Acer E627, with windows 7. I cannot connect it to our home network using a D-Link DIR-655 router. It has always worked fine. Other computers can connect to OUR network, we have wireless computer downstairs, it connects, no problem. I went to a local coffee house with free internet and it worked fine!! The emachine sees our network, but won't connect. All the bars showing the network strength are green, the signal is very strong, I can even see my neighbors network. If I type in the wrong Pre-Shared Key, I can't leave this dialog box. So, everything seems good here, except the emachine cannot connect to our network. Error message is Windows was unable to connect to the network. Trouble shooting dialog box does not identify the problem. I manually setup the emachine with the info from the D-Link admin areas, it shouldn't be this hard! Various Info: D-Link DIR-655 Firmware Version: 1.02 Hardware Version: A1 emachine has: Microsoft Virtual WiFi Adaptor Model: Broadcom 802.11g Network Adaptor Settings 802.11 Mode : Mixed 802.11ng, 802.11g and 802.11b (the new emachine supports 802.11g) Security Mode : WPA- Personal WPA Mode : WPA2 Only Wireless settings I type in on the new emachine Wireless Network Name: THE Network Encryption: WPA2-PSK/AES Pre-Shared Key: qwerty11 Do we need a windows 7 updated driver for the Microsoft Virtual WiFi Adaptor in the emachine? If so can I get the link?
  • 66 Answers
WPA is not very stable and I have seen many problems with this. Simply change router setting to be configured with WEP and use a good strong password in hex 0-9 and a-f . WPA is horrible any way, and who the heck is gonna sit out side your home to hack it? It is not a WIN 7 problem but more like aging encryption.
Posted on Feb 11, 2010
2 Suggested Answers
SOURCE: Dir-655 works with XP and Mac which can connect
Go to 192.168.0.1 and login. Then go for the 'Setup' tab on the top and look for the 'Wireless Settings' tab on the right.
You can now automaticly setup your WLAN connection and afterwards you can go to the 'Manual Wireless Network Setup'. Over there you can change the 802.11 mode.
  • 802.11b only
  • 802.11g only
  • 802.11n only
  • Mixed 802.11g and 802.11b
  • Mixed 802.11ng and 802.11g
  • Mixed 802.11n, 802.11g and 802.11b
Go for the last one that uses n,g and b and you will be sure your computer can connect :)
Posted on Jan 15, 2010
When I tpye in 192.168.0.1 always says page not available,
Yes connect your PC and Router with Ethernet cable and try again.
Your router's manual is here, refer it for reset your router, it's best idea to reset and whole solution. http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20655/Manuels/DIR655B1manual070312v23pdf.pdf
Sep 26, 2012 | D-Link DIR-655 Wireless Router
I have bought a d-link dir-655 router. Trying to install it now. I do not have a CD-room.. Trying to enter the router by typing http://192.168.0.1 in the url-window in Firefox (also google crome), but...
You must be on the same network as the Router is your computer only connected to the Router ( with lan cable ) if so what is the IP address on your computer. If you are on the same network as the router the computer should have the IP address 192.168.0.xxx if not check if your computer has DHCP in the properties for the netcard, and change it to DHCP if it is not and then restart your computer and try again. I hope this will work.
Nov 13, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have a DIR 655 D Link router and I can't save changes.
Lots of possibilities, especially if the wireless device and your PC are older - the DIR 655 doesn't support wireless protocols 802.11 a and b, for example, only the newer g and n.
Start with getting the router software up to date (see http://us.dlink.com/products/connect/wireless-n-gigabit-router/ )
using an Ethernet link to a PC, and then debug the wireless access. The DNS message could be caused by the Windows wireless adapter config having a manual IP address vs the router being set for DHCP (dynamic) or vice versa.
Sep 10, 2017 | D-Link DIR-655 Wireless Router
Problem with DIR 655
On the laptops, check that your Internet is set to use "Private" networks as opposed to "Public". Private networks allow others to see you and you to see others on the network, once you've entered the proper pass phrase as set up in the router's software. Your Manual for the router has the instructions you need to complete this process.
Dec 15, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My dir-655 works great via laptop wireless but the
Follow the steps below on the concerned computer:
1. Click start button (extreme bottom left corner of the screen).
2. Click Control Panel from the list.
3. Click on Network Connections.
4. Right click on Local Area connection icon and click on properties.
5. Select Internet protocol TCP/IP from the list of components and click on properties.
6. Select "Obtain IP address Automatic".
7. Select "Obtain DNS server Automatic".
8. Click OK and close the window.
if the issue persists then try changing the cable between the router ad the computer. You may also try connecting the computer direclty to the modem to isolate issue.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 21, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wireless security not working on my D-Link DIR-655
- Log on to the configuration page of the router
- Go to Manual Wireless Network Setup
- And Change the Channel width to different one
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Where or how i will find the wep key for d-link xtreme n dir -655
you dont find or you dont generate WEP key in your D-link my friend :-)
if you are using windows operating system ...   try this
go to netwrork settings 2) wireless network 3)there you need to cerate new connection if you dont have one already 4) after creating go to properties of that wireless network and use one of the option there to generate the WEP 5) that must me used both in your windows and in your D-link that means type that wep key that you have in your windows in your d-link
Hope it solves ...;-p Thanks
Dec 18, 2008 | D-Link Xtreme N DIR-655 Wireless Router
How to connect USB NAS to D-Link DIR 655
if you update your router firmware to the most current you can use the usb port to connect to an external hard drive or flash drive but you have to install drivers on the computer you want to access it with also i believe only one person can access it at a time
Oct 25, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
1,123 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
