Question about Toshiba Satellite Pro L300 Notebook
How do I take the keys off too clean, if I can take them off
    Brigadier General:
  • 4,090 Answers
DONT DO IT!
Use a paintrbrush to clean between the keys or even a can opf compressed air to blow ( Vacuum cleaner even to **** dirt out) Wipe keys with DAMP ( not wet cloth.. no detergent) Some chemicals will remove the letters on keys. Avoid using hand creme as this will destroy keys fast.
Please rate my help++++Thanks for using FIXYA
Posted on Feb 07, 2010
Take apart handset to clean keys
The handset keys may not be accessible for cleaning.
Jan 07, 2014 | GE Lands Phones
Tip
How to Clean the Laptop Keyboard
The following will completely solve keyboard problems and return the keyboard to perfect operation.
This will require about 2 hours time once you have collected the proper cleaning materials.
Cleaning materials:
  • Cotton swabs
  • Cosmetic foam rubber cleaning pads ( use only with naptha (lighter fluid), NOT alcohol)
  • Paper towels
  • Rubbing alcohol
  • Water
  • Lighter fluid (naptha)
  • Fine tipped tweezers
  • Scissors
  • Kitchen strainer
  • Household cleaner, Windex or equivalent
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive.
  • This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows:
DISASSEMBLE:IMPORTANT: Make a keyboard map so you know where each key goes.Carefully pry each key loose with a small screwdriver and place in a container. They pop off. DO NOT use excessive force. There may be a small rubber piece for each key. Remove all of these and place in a separate container. CAREFUL, these are small and like to jump away.CLEAN KEYBOARD ( do this well...... you will be wonderfully rewarded ) Clean the keyboard with cotton swabs SLIGHTLY DAMPENED with water. Replace these often and BE SURE they are only slightly damp. If they are too wet the excess water will contaminate the keyboard through capillary action. This will clean all water soluble contaminants like Coca-Cola, coffee, and sugar residue. For the very small places, cut the foam rubber into small pieces and use the tweezers, again SLIGHTLY DAMPENED, for cleaning. You must clean each and every key space, inside and out, this is critical since this is where the key touches and moves. Repeat this procedure again using rubbing alcohol and cotton swabs but NOT the foam rubber as it disintegrates when used with alcohol. Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SPACE BAR.
CLEAN KEYS:Some keys may have wires attached and some grease on them, clean these first with cotton swabs and naptha (lighter fluid). Remove all traces of the grease. Place all keys in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Rinse thoroughly with hot water and place keys on paper towels to dry. Let dry completely.
CLEAN RUBBER COMPONENTS:Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don't lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely.
LUBRICATE KEYS:Place all keys bottom-up on a paper bag. Lightly coat the keys, at a 45 degree angle with Super Lube Dry Film lubricant. Do this from all 4 sides to assure penetration and coverage into the small and critical guide spaces inside each key. Let dry ( this happens nearly instantly). DO NOT overdue this step as the carrier solvent may affect the plastic.
LUBRICATE KEYBOARD: Mask off the laptop with paper and scotch tape. Apply lubricant (as above in LUBRICATE KEYS) to the keyboard and let dry. All right, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE:Place all rubber components into the keyboard. Install keys with wires. Make sure wire is secured in the key, usually snapped into place. Place ends of wire in the guide slots adjacent to the key location as you align the key. Firmly press down to snap the key into place. Install the rest of the keys by aligning and firmly pressing down.
on Jan 03, 2011 | Computers & Internet
Beer spilled on my keyboard so they feel really sticky. How can I clean it?
  • Cleaning materials:
  • Cotton swabs
  • Paper towels
  • Rubbing alcohol
  • Water
  • Scissors
  • Kitchen strainer
Proceed as follows: DISASSEMBLE
CLEAN KEYBOARD
Finally repeat this procedure using naptha (lighter fluid) and foam rubber. You can clean even the smallest key guides with small pieces of foam rubber and tweezers. This action will remove any petroleum based contaminants as well as the grease that is sometimes used on the wider keys which may have guide wires, for example, the SCACE BAR.
CLEAN KEYS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don?t lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely.
LUBRICATE KEYS
LUBRICATE KEYBOARD
REASSEMBLE
Oct 30, 2010 | Dell Studio 17 Laptop
Kid spilled soda now keyboard will not type
Hi There !!
Thank you for choosing Fixya. The chances are rare that it would work, because liquid may have done damage to the integrated circuit.
But we can give it a try:
What you will need:
  • lint free cloth.
  • dry cloth or duster.
  • suitable cleaning fluid (isopropyl alcohol).
  • cotton buds.
  • Can of compressed air or vacuum cleaner.
  • Flat tip screwdriver (optional for thorough clean).
Shutdown your PC and remove the mains plug, unplug the keyboard(remember where it was plugged in) and hold it upside down to releaseany debris from inbetween the keys.
This is where the patience comes in, make a note ofthe position of all the keys or you will have trouble putting them backcorrectly, alternatively just remove the letter keys A - Z from the keyboard (which is where the most of the dust/debris will be) and refer to fig 1.4 as a reference to put them back.
All the keys can be removed although the larger keys (space bar, enterkey, shift keys, backspace, caps lock, etc) can be difficult to putback so you might avoid removing them.
Remove the keys using the screwdriver, ease the screwdriver under the key and gently lift the key top off (see fig 1.3).
note: don't forget to make a note of their position !! remove-key-cap.jpg keyboard-layout.gifWhen you have removed all the keys (except any keys youwish to avoid) use the compressed air (or vacuum cleaner) to remove anydust and debris from inside the keyboard.
Now is a good time to give the keys a proper clean, for bestresults clean each one individually (the patience thing again) with thecloth and cleaning fluid, when clean, wipe them over with the drycloth.
Before replacing the keys, take your lint free cloth anddampen it with your cleaning fluid (don't put the liquid directly onthe keyboard), give the surface of the keyboard a good wipe overensuring to clean as much as possible any keys that you haven'tremoved.
When the keyboard is nice and clean replace the keys according to your notes or if you have just removed the letter keys use fig 1.4 as a guide, to put the keys back on position the key in place and press gently but firmly until it clicks home.
After replacing all the keys give the keyboard a quick wipe over with your dry cloth and you have a nice clean keyboard.
Hope this will help !
Regard's
Sep 03, 2009 | Computers & Internet
Keyboard keys keep sticking how to solve this issue
Hi there.
To clean the keyboard properly buy a can of compressed air, wipe the keys with a clean, damp cloth. then get a clean, dry paintbrush and gently brush between the keys, then get the compressed air give short bursts of air to remove the debris, periodically turn the computer on and try the keys to see if any improvements are made.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | IOGear (GKM541RA) (DHGKM541RA)
Acer 240 laptop keyboard took sip of coke
Proper cleaning and lubrication as described here will restore your laptop keyboard to the snappy and smooth performance it had when new. This will require about 2 hours time once you have collected the proper cleaning materials.
Cleaning materials:
  • Cotton swabs
  • Paper towels
  • Rubbing alcohol
  • Water
  • Scissors
  • Kitchen strainer
  • Super Lube Dry Film spray (critical - DO NOT SUBSTUTUTE !) K-Mart automotive. This is a PTFE (teflon) based lubricant which dries perfectly DRY and is ideally suited for this application.
Proceed as follows:
DISASSEMBLE
CLEAN KEYBOARD
Do this well...... you will be wonderfully rewarded
CLEAN KEYS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don't lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely. LUBRICATE KEYS
LUBRICATE KEYBOARD
Alright, you now have perfectly cleaned and lubricated keys, keyboard, and rubber components.
REASSEMBLE
CONTRATULATIONS, you now have a squeeky clean keyboard!
Jan 12, 2009 | Acer TravelMate 240 Notebook
4 keyboard keys aren't functioning
Chances are there is a physical problem with the keyboard. Are the keys sticky or do they press normally and still not work? If the keys are sticky when you push them you can remove the keyboard and keys and try to clean the keys with rubbing alcohol. Chances are the keyboard is not defective and the link below will help you take care of that problem. If you need any further help let me know.
I am including a link to a new keyboard for your model Laptop. They are fairly reasonable condidering they are laptop keyboards.
Jan 09, 2009 | Acer Aspire 3000 Notebook
Unable to print BLACK
The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
    1. Press the Ink Management key.
    2. Use the up or down navigation key to select TEST PRINT.
    3. Press Set to confirm your choice.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
Cleaning the Print Head
  2. Use the up or down navigation key to select CLEANING.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
I hope it helps!!!
Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
Logitech cordless keyboard erratic after cleaning keys
seems to be that you may have accidentally swept some dirt underneath the keys.
try pressing each key individually in word and narrow down the affected key or keys, then remove the affected keys (using a keyboard key removal tool, or very carefully by hand) and clean underneath the key with a small dry clean brush both under the key and the board section it lay in, then replace the key and type the key again, if that has no luck then try the process again.
hope this helps
kev
Dec 01, 2008 | Logitech 967437-0403 Keyboard
Sticky keys
You can try cleaning the keyboard. most keys can be removed easily by just pulling them out.
  • Cotton swabs
  • Paper towels
  • Rubbing alcohol
  • Water
  • Scissors
  • Kitchen strainer
CLEAN KEYS
Place all rubber components in a kitchen strainer. Spray with household cleaner and let stand for 5 minutes. Use stopper in the sink so that you don�t lose these if they jump out of the strainer. Rinse these thoroughly with hot water and place on paper towels. Fold the towels over and press to squeeze most of the water out of the pieces. Let dry completely.
LUBRICATE KEYS
LUBRICATE KEYBOARD
REASSEMBLE
Nov 16, 2008 | Compaq Keyboard
Toshiba Satellite Pro L300 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
