Question about Amana Refrigerators
The refrigerator keeps making a loud buzzing noise. It is not the ice maker filling up with water. The noise runs for about 5-10 seconds every hour or so.
  • 311 Answers
Sounds like your starting components are bad on the compressor. If the freezer section begins to loose temp then this is probably the case. They will try to start the compressor and then it will kick off on its overload. However this will usually occur every 10-15 mins when they are completely toasted. Your compressor may be starting up part of the time and not starting the rest. Either way you will probably need new starting components on the compressor. You could also check to make sure your condenser fan motor is running (in the back of the ref behind the access panel) because this could cause the compressor to overheat but usually wont cause a buzzing noise.
Hope this helps _MJ_
Posted on Feb 07, 2010
Replace motorized damper
It may be possible that water is splashing from the icemaker fill tub and running down into the fan area and freezing. When the refrigerator goes into defrost the ice thaws and the noise stops.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Periodic loud buzzing noise
Two main possibilities:
1.) If the refrigerator has an ice maker but you are not making ice, the solenoid valve will open every hour or so to allow water to fill the ice maker. That valve wears out and makes more noise as it ages. There is a metal rod/bar that can be lifted up to stop the ice maker from cycling.
-or-
The compressor and the associated starter cap may be failing and it can make odd noises when it starts back up after the defrost cycle. Time for a professional to take a look.
May 21, 2010 | GE Profile 22.2 Cu. Ft. Side-by-Side...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Apr 28, 2009 | Refrigerators
Ice maker noise when filling
replace the water fill valve it is at the bottom where the water line conect to the unit
Nov 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Intermittant noise
hi thanks for the question that buzzing noise is probably coming from the ice maker water valve that's about the time it cycles i would not worry about its fine just a little noise thanks the appliance doc but if it s too noisy replace the water valve
Sep 20, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
473 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
