Question about Compaq Presario 2100U Notebook
Presario 2100US not powering up
My sister in law's presario was booting up when suddenly a message popped up and she hit enter and next thing we know it is going into hibernation. Repeated attempts to boot it up failed as it now does not even power up, The battery light shows on but none of the other lights are coming on.
How do I proceed?
    Problem Solver:
  • 10 Answers
Remove power supplay
remove battery
press and hold power button for 1 min
release button
plug the power supplay
turn on laptop without battery
Posted on Feb 22, 2008
My Compaq Presario 2100 heats Up & Switch's of With No Warning
Any Sol???????
Posted on Apr 30, 2008
Laptop powered up lights on keyboard are lite fan's running but won't boot up
try booting up in safe mode first.this somtimes sorts it out.
if not let me know.
Mar 24, 2015 | HP Compaq Presario 2100US Notebook
How to reset a harddrive?
To restore your HP laptop back to the factory default, boot up with the Recovery CD and follow the on screen instructions.
If you do not have a recovery CD for your model laptop then you can get one from the HP WEB site.
http://welcome.hp.com/country/au/en/cs/support.html
Oct 10, 2012 | HP Compaq Presario 2100US Notebook
I already asked aquestion but solution didn't work. I got a computerfrom my sister-n-law and everything is setup with a user name and I tried to delete user name and now com says............. User's...
Boot into recovery mode from GRUB menu, at the prompt, change user password again to something easy to remember.
passwd user
Then, change the ownership/permission of /home/user/.dmrc to you won't get that error/ignore message the next time you log in.
chown user:user /home/user/.dmrc
chmod 644 /home/user/.dmrc
Now reboot.
shutdown -r now
Mar 05, 2011 | MSI Wind U100-030US Laptop
On my Compaq Presario 2100US my screen has started going black intermittently while running. I then have to power it down using the power button because I can't see the screen to shut it down properly. ...
  1. Remove the battery & switch on the PC in AC mode.
  2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
  4. If still no display, connect an external monitor, check if display is comming.
  5. If Display is coming then your LCD need to replace.
Aug 20, 2010 | HP Compaq Presario 2100US Notebook
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Safemode prblem
Note that the F8 button must sometimes be pressed within a .5 second timeframe. You can either keep trying and rebooting or use the following site: For Windows XP, try this: http://netsecurity.about.com/cs/windowsxp/qt/aaqt_safemode.htm The same may also work for Vista. I hope this helps, Yannick
Jun 12, 2009 | Compaq Presario Notebook
PRESARIO 700 ERROR ON BOOT Hello! Every time when I switch on my presario 700, on the screen show: ERROR PCI on motherboard, device 09, F1(boot) and F10 (setup). OS is XP pro. What is wrong?
If you know how to set up the bios hit f1, if not hit f10, it will boot up and you will need to reset the time and date as they will be wrong. The PCI error refers to a PCI slot, which for some reason isn't functioning properlly. If you run the disk with your motherboard settings that may have come with your motherboard it may just be a driver. If you hit f1 then you will be in the Bios screen. There the keyboard is used to navigate. The mouse won't work, Arrow keys for up down and side to side, and the escape key to get out of a menu or menu item, and enter to select an item. So on the first screen, you will need to adjust the date, time, and year. each time you do this you must hit enter to proceed to the next item. once you get all of the settings right hit f 10, and enter to reboot. So I gave you both ways. If you still have the problem, check the cards that are in your motherboard, there may be a loose one, also try to pop out the battery inside the case, not the laptop battery, if it continues to happen, you may have to pop that little battery that controls the settings for startup, it will reset your saved motherboard startup settings, and once in a while the battery may be bad, which can also cause the kind of problem you describe.
Apr 20, 2009 | Compaq Presario 700 470024-192 Notebook
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario 1255
If there is a cancel button with the password prompt, hit cancel without entering a password, or hit enter without entering a password. Sometimes if there was a password, even though there may not be a password currently, the system will still prompt for one, if you enter a password then it locks. The other things you can try is: At start up, hit the F8 key and go into safe mode, log on under the administrator and clear any user passwords in the user accounts. You can also try, at start up, entering the bios or utility set up and check to see if the bios password setting is enabled, then disable it. Rarely, but on occasion, a hard drive will fail and cause the password prompt. If this is the case, then the hard drive will need to be replaced.
Jun 27, 2008 | Compaq Presario Notebook
Won't boot up. Help!
could be a number of things, but first check the disc shaped CR2032 cmos battery located on the motherboard, in case it is flat. Then when the pc boots, you should get the cmos menu to enable you to alter the time and date. If still no boot, when it is booting press F8 and see if you can get to safe mode, and when in the menu select last known good configuration and press enter or a reboot. If you see no bios screen and the flashing cursor appears in the top left of the screen the cmos chip on the board is damaged, and the motherboard needs replacing.
Aug 16, 2007 | Compaq Presario 6010US (470027-054) PC...
Compaq Presario 2100U Notebook Logo
168 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
