Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics and no error codes revealed. The Dell "My Tech Team" experts now want to replace the solid state hard drive. Doesn't seem logical to go there? I think it may be more related to connector to display and in some cases power failure seems to have occurred when display is angled or being angled back at greater than 90 degree angle. Please don't waste my time unless someone has seen and can identify cause of this problem.
  • 952 Answers
Thanks for using FixYa.
Your battery flex cable might need re-seating. I will give you detailed instruction on how to do this. This information is from our Dell Technical Support Vault. Please do not disclose this information to others. Another warning is that you might void your warranty if you damage the flex cable so be very careful.
Before anything else... remove the AC adapter from the laptop.
Locate the three slots on the bottom of the system.
Dell ADAMO 13 w/Vista 64 - 34e9312.jpg
In each slot, a metal tab needs to be shifted. This unlocks several tabs that hold each side of the battery / bottom cover.
Locate one of the side slots.
Insert the special battery latch tool so that it engages the latch. Slide it toward the back of the sDell ADAMO 13 w/Vista 64 - 78fcb5d.jpg/>
Insert the battery latch tool in the slot on the other side of the system. Slide the latDell ADAMO 13 w/Vista 64 - d56205d.jpghe back of the system.
Insert the latch tool in the slot aDell ADAMO 13 w/Vista 64 - 8019e39.jpg of the system. Slide the latch toward the right.
Pry up the battery / bottom cover with a plastic scribe and tilt it up toward the back of the system.
Posted on Feb 14, 2010
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
Why My Inspiron mini will not start?
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check hoe the Power LEDs on the system, battery and AC Adaptor react. Then I can check and help you further.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron Mini 10 Notebook
Dell adamo 13 Laptop is dead and not powering on
I would verify you are getting the right voltage out of your AC adaptor with a meter. I believe it should be 15vdc. If you are not getting the correct voltage buy a new one off eBay and charge your battery.
If you are getting the right voltage but the unit doesn't power up, remove the battery and check its condition with a meter. If the battery is bad, you may be able to run the laptop with the AC adaptor only.
http://news.cnet.com/2300-17938_105-10000721-1.html Take look inside the Dell Adamo Photos Cracking open the Dell Adamo
Jan 14, 2014 | Dell adamo 13 (dacwaq1_1) PC Notebook
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Feb 07, 2010 | Office Equipment & Supplies
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
Dell Inspiron Battery problem
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Oct 29, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
