Question about Panasonic Heating & Cooling
How to change battery for aPanasonic Heat pump remote control ?
    Guru:
  • 415 Answers
Here is a link to a panasonic remote control. It appears the two AA batteries are located under the cover found just below the buttons on the front of your remote. Look at the link below and see if this remote looks similiar to yours.
https://support.panasonic.co.nz/docstore/CSA24%20book.pdf
I hope this helps. Good Luck!!!!
Posted on Feb 07, 2010
My hitachi heat pump remote is not working. Wont reset and cant set the clock. Cant get the heat setting above 3 degrees!! How can I reset it Have changed batteries and hit reset . Nothing helped
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]/
Jun 21, 2018 | Hitachi Televison & Video
Our Panasonic Heat Pump refuses to turn on. Can you help.
More than likely there is a power related issue within the furnace or the heat pump... Control power for the heat pump originates from the furnace control transformer. If you turn the thermostat fan setting to the 'on' position and the indoor fan comes on, the control transformer is delivering 24v control power to the thermostat circuit. If not, there could be an issue to resolve first. If the blower does come on, that's kinda good but it then means there could be a power or control issue within the heat pump itself. Any issue within the heat pump beyond making sure the 240v applied voltage is at the unit will usually be beyond the average homeowners capability to resolve.
I know this isn't much to go on, but there is such a tremendous volumn of issues that could be effecting the systems operation it would take pages to just scratch the surface. You are going to be limited to checking the basics, then my suggestion is to call a reputable service organization to resolve the issue.
Dec 27, 2014 | Panasonic Heating & Cooling
Why doesn't remote control communicate with Fischer heat pump mini split system
It sounds like the batteries leaked and oxidized the terminals. If you cannot get them clean enough then I would suggest getting a new reomote from the manafacturer.
Aug 24, 2014 | YMGI R410A Ductless Mini Split 16 SEER DC...
Remote control malfuction
04Feb14
In some states and provinces of Canada, the Lloyds 'remote' CANNOT be programmed into cable vision providers!!!!!!!!!!
One provider 'Shaw Cable' has never heard of Lloyds.
What's up with this.....having to use Lloyds remote to adjust volume and mute, while using Shaw's remote to channel change.
That's just awful. Archie Bunker has it bedda.
Feb 04, 2014 | Klimaire Universal Mini Split Remote...
My remote will not change the fan speed on my mini split heat pump in the heat mode but will change speed in cooling mode. checked batteries and pressed restart button no changes
in the heat mode the fan mode run automatically first in low mode and after a while it run normally ,how you set on the remote.if you can-t set on the remote is possible to have problem to the remote.
Dec 12, 2013 | Comfort-Aire EHW 12 Air Conditioner
I changed battery and pressed ACL but remote is not working
check the infrared led on the remote by holding the lens of a camera phone to it like taking a picture. press any key on the remote. if the remote is fine you should see the led flash when pressing the keys , if not then the remote would probably be faulty.
if you see the led flash then it would more than likely be the evaporator remote pickup that is faulty and needs to be replaced
Nov 01, 2013 | Sanyo RCS-4MHVPIS4U Wireless Remote...
Remote control not working for Haier Air Con. HSU 09LE08
My problem is indicator blinking on off and after 30minute air cond good function and after 4hours air cond breakdown.
Feb 15, 2013 | Heating & Cooling
Akai airconditioner AC-KS24HRC Changed batterirs in remote can not get heat mode icon on remote therefore no heating.Still under warranty but can not find Akai repairer Newcastle N.S.W. Australia...
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Jul 15, 2009 | Heating & Cooling
Need to program tv into remote
At universal remote control i.e URC22-9A:
Suitable codes for panasonic TV:
Try 001,003,019,037,040,106,110.111,112,114,190,241
or see booklet of your remote control.
Feb 18, 2008 | Televison & Video
Feb 18, 2008 | Panasonic CT25G7 25" TV
Heating & Cooling Logo
2,476 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
