Question about Gateway FPD1960 19" Flat Panel LCD Monitor
There is a 2in. wide series of thin vertical lines on the left side is this normal?
  • 12 Answers
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Posted on Feb 07, 2010
Thin green vertical lines
if its only one channel its your cable service, if its constant try unpluging your tv from the wall for 30 seconds to reset it, also try reconnecting any AV cables for the source you are using, If you are using a Coaxial cable unscrew it and check to see the copper needle is not bent or damaged.
Dec 19, 2013 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
2 thin vertical blue lines, near center and right side. Do i need to replace LRC buffer boards. Z50p3 50 in plasma.
By thin line I assume its one pixel in width. A single pixel wide line is an indicator of a defective panel.
Oct 30, 2013 | Zenith Z50P3 50 in. Plasma TV
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
My dryer is leaving burn marks on my clothes . burn lines are typically about 2in long 1/2 in wide and all heat settings leave the burns
thermostat poss faulty or air vents blocked (i have seen a drier where the owner never cleaned the outlet vent and you could heat the house almost....
Feb 16, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
When I turn on my tv all that comes on is three 6"blue lines no picture is my tv toast
Hi:
If these lines are at least 2 inches wide then the problem is the display driver boards or some call them the Buffers boards, if the lines are less then 2in in wide and are very thin lines then the PDP is bad (Screen).
Nov 08, 2009 | Akai PDP4206EM Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Monitor screen with pink line
While I've never seen the stripe be pink, it's not impossible for it to appear that color. Your monitor is bad, and isn't easily or cheaply fixed.
Apr 30, 2009 | Computers & Internet
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
113 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
