Question about DSC GESTETNER - DSc38u Color Printer
Gestetner dsc38 error code
I have a error code of sc 386 on my gestetner dsc38 printer. I think it might be associated with the black drum but find no information on what that error means.
  • hasem May 08, 2008
    error code CS201
  • Jafta May 11, 2010
    Could be a few things. Check SP3-975 it will show you a number . if you give me that number i can help with solution. enter sp mode ( funtion clear/107/hold down clear(red button))
  • 903 Answers
Sc386 is a color density error specific to black, but it usually is caused by the development unit rather than the drum. If the drum is old or worn you may want to replace it, but almost every time, replacing the DV unit will get rid of the sc386 error code.
Posted on Jul 29, 2010
    Problem Solver:
  • 10 Answers
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Posted on Oct 03, 2009
Error 120 code
To reset the SC code follow these directions:
Resetting Ricoh Savin Lanier Gestetner SC Error Code
Error code 120 is scanner home position sensor problem. If it's a recurring problem, here are some troubleshooting tips:
SOLUTION:
Turn the main switch off and on.
Check the wires between Home Position sensor and the SBU.
Fix scanner board or the SBU .
Check the wires between scanner motor and the scanner I/O board
Fix the scanner motor.
Fix the Home Position sensor.
Fix pulley, timing belt, the scanner wire,
Fix the carriage.
Jun 17, 2014 | Gestetner Office Equipment & Supplies
SC:500
At the back, replace the main motor.
Feb 28, 2014 | Gestetner DSM615 Black Toner Cartridge...
Gestetner dsm730 error code sc590
SC 590 - Toner collection motor error.Possible causes:
- toner collection motor defective
- too much load on the drive mechanism
- poor toner collection motor connector connection
- toner collection motor sensor defective.
Reset procedure:
1. Turn OFF/ON the power switch.
If the trouble don t reseting press the Clear (yellow) key press 107 press and hold last more 4 seconds the Stop/clear(red) key,enter inSP mode,then turn the main power switch OFF/ON.
Feb 04, 2013 | Gestetner DSm730 Black and White Copier
Gestetner DSM645SP Error Code SC 322
After research it seems this problem is not easily fixed.
Jan 16, 2009 | Gestetner - DSm645sp Digital Imaging...
SC680 error message on a Gestetner DSc38
The machine has a problem reading the memory chip on the toner.
Check if the chip is not lose or damaged or durty
Check the harnass or the chip reader and pins and clean.
Replace toner
after replacing the toner and the problem is still there you can do a engine clear.
contact me drbrain@webmail.co.za for doing engine clear.
Dec 22, 2008 | Ricoh Aficio AP3800C Laser Printer
Error Code with Ricoh 2238c machine
Which kind of error code ?
SC-xxx something ...
Jun 07, 2008 | Office Equipment & Supplies
Color registration
Whenever you change the fuser unit you have to do the fuser registration.You have to use the manual feed tray with A3 or 11x17 paper for this registration.The details should be inside the new fuser box carton.
May 16, 2008 | DSC GESTETNER - DSc38u Color Printer
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
430 people viewed this question
Top DSC Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a DSC Office Equipment and Supply Expert? Answer questions, earn points and help others
