Question about Audiovox VM9512 Car DVD Player
How do you reset the code on the xdvd9101 dvd player
I forgot my password for my dual xdvd 9101 how to unlock it
i bought a truck with thedual xdvd9101 radio and cant dont no the cod for it can you help me
Feb 13, 2012 | Dual Electronics XDVD9101 Car Video Player
How to stop my dual xdvd9101 screen from flashing
Hello
Do a factory reset to your set. Just refer to its user manual. OK.
Feb 12, 2012 | Dual Electronics XDVD9101 Car Video Player
My battery died and i dont have the password i have the xdvd9101 model.
you will have to reset it to factory settings, unfortunately there does not appear to be much information on how to actually do this, you will need to contact the manufacturer for more information.
1-866-382-5476
Aug 25, 2011 | Dual XDVD8182 Car DVD Player
I just bought a dual xdvd9101 indash dvd player and cant get the brake bypass to work
However, some units use different methods. Some require seeing a pulse (i.e., power-ground-power-ground-etc.), resulting in the annoying need of pushing the e-brake a few times before your video will pop up. This can generally be recreated by using a 3-prong switch (you can get one at AutoZone). Connect it backwards -- the ground to power, power to ground, and the "Load" to the Parking Brake wire on the back of the radio. Flip the switch back and forth a few times and sometimes the video will pop up.
Some fancier units cannot be cheated. They use an internal gyro mechanism that detects movement.
Some even feature bypass codes. By pressing a certain combination of buttons on the remote then entering in a code it will permanently allow video.
Be good.
Dual DVD
Play Dvd for few seconds until you hear sound
Press Stop Twice
Then enter on remote 26604 the press enter
Nov 15, 2009 | Car Audio & Video
Where does the yellow and blue cable connects to?
The yellow connects to power, if the blue wire has no stripe its an accessory and simply needs connected to power if the blue one has a white stripe its the remote turn on wire for an amp.
Sep 17, 2009 | XO Vision XOD1742BT Car DVD Player
Bypass break switch
Yes, this unit will work with a toggle switch.
Aug 10, 2009 | Jensen VM9510 Car DVD Player
Parking brake bypass
the 9101 was built so you can not bypass it
Aug 01, 2009 | XO Vision XOD1742BT Car DVD Player
DUAL XDVD9101
the 9101 is built so you cant bypass
May 08, 2009 | Audiovox VM9512 Car DVD Player
Bypassing the emergency brake on the xdvd9101 with a toggle switc
ground wire to a normal 2 position toggle switch. put dvd in. turn switch on then off then on. there ya go.
May 03, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Audiovox VM9512 Car DVD Player Logo
178 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
