Question about Acer Computers & Internet
Acer Travelmate 5602 - I have a problem with the hinge on the lower left side of my screen. It is so tight that the screw in the lower left corner has striped it threads and the outer cover is loose also. How do I repair this?
  • 35 Answers
You may have to purchase a new hinge, make sure it come with screws and all. You may have been the unlucky person to receive faulty hardware from the manufacture.
Posted on Feb 07, 2010
Hinges broken while opening
i have fixed one by replacing the scews on each side my kids like to carry it around by the screen , you may have to put a small washer to hold the screw from going in to far try it good luck don
Nov 02, 2012 | Acer TravelMate 4740
Hinges are loose on Toshiba NB505N508BL
Turn off the laptop, and remove the cord from the outlet.
Lift the laptop lid so the screen is in an open position.
Locate the small screws in the lower left and right corners of the screen.
If the screws are concealed by plastic plugs, carefully pry them out with a flathead screwdriver.
Use a Phillips screwdriver to turn each screw in a clockwise direction to tighten it.
Move the screen up and down to test it.
If it is still not tight, twist the screws counterclockwise to remove them.
Store the screws in a safe location.
Slip the tip of a knife into the seam where the front and rear of the screen meet.
Lift up on the knife to pry open the cover, and continue until the back cover is removed.
Rotate the laptop so the rear of the screen is facing you.
Locate the screws at the lower left and right corners of the screen.
Twist the screws in a clockwise direction to tighten.
Gently push the back of the screen into place with your fingers until it snaps back on.
Turn the notebook around so the monitor is facing you.
Reattach the screws to the bottom left and right corners of the screen.
Push the plastic plugs back over the screws if your computer had them.
hope this helps
Oct 11, 2012 | Toshiba NB505N508BL 10.1" Intel Atom...
My acer travelmate 2500 overheats when playing games
The cooling on the Acer Travelmate 2500 is worse than most because it contains thin copper heatsink fins which grab the dust as it flies past. Great for getting rid of heat; terrible for getting rid of dust.
prise off the two corner pieces that cover the hinge for the screen. Underneath there are two screws. Remove these, then peel away the keyboard and the plastic covering. There you will see the fan system. Four screws (on springs - careful) will have this away but be aware of the power cable which is tucked in behind a piece of metal. At all times be careful not to damage the keyboard ribbon cable which is usually pretty fragile.
Another few screws (tiny ones) will have the top of the fan off then you can clean and put it all back together. The result: a laptop that actually blows air through and cools what it should.
Kindly rate if this helped Regards
May 13, 2011 | Acer TravelMate 2500 Notebook
I have an acer travelmate 517TE. I want to remove
There may be other screws hidden behind plastic concealing covers.
The front bezel can have retaining clips that clip that lock onto the lid and may also held in place with double sided tape.
Use a thin flat blade (careful not to scratch the LCD screen) and slip it between the bezel and the LCD screen and gently prize it away from the screen. Start at the bottom of the screen near the hinges and work along each edge.
The inverter will be located on the bottom edge of the screen between the hinges.
Oct 06, 2009 | Acer TravelMate 517TE Notebook
Trying to replace hard drive on Acer TravelMate 800
if its anything like my acer aspire 3000....if you tip it up and look to your left upper corner there is a small rectangle almost sqaures piec youtake out two  screws  undo another screw holding the housesing pull the tab on housing and voila! hard drive.happy hunting-z
Jan 22, 2009 | Acer TravelMate 512T Notebook
Kenmore elite top loader electric washer
you have poor contact with the left lid hinge and the lid switch.1st open the lid and check the 2 phillips head screws on the left side of the hinge.if they are loose tighten them and try mach.if the screws are tight,the lid switch might need to be replaced or adjusted.there will be 1 screw in each corner of the back of the console facing down.remove and flip console up,if there are no screws,take a putty knife and slide under front left and right corner of console and flip console up.the lid switch will be on left.if it is not broken out of socket,adjust hinge bar underneath switch by removing switch and bending silver bar up SLIGHTLY
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Pictures
Use the software that came with your computer to display your picture on the screen. There should be a camera button on the lower left corner of the screen that allows you to take a picture.
Jul 02, 2008 | Acer TravelMate 2300 Notebook
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Stiff hinge pin
These systems use a pretty generic hinge set-up. These can be dealt with in two ways, one involving a safer method for future adjustments. The hinges are two separate bars on each side of the monitor with friction cuffs that use the tension between their two pieces to hold the monitor stiff. Generally my experience with Acer models is that they ALL ship with pretty stiff hinges, which is a double-edged blade. Stock hinges that don't click when fresh have a tendency to need replacing after a couple years, where as my acer TM4K hinges are still strong today after 4. The best way to loosen these babies up is to just use it. About an average of 75 open/close cycles break in the hinge to where it stays nice & tight, but stops clicking or cracking. The other way, which is for those who are afraid the LCD housing will crack it's so tight, is to take the monitor off, but not apart, carefully using two pairs of needle-nose pliers, hold steady the monitor end with one set and with the other, flex the flat end of the now loose hinge back and forth as far as you can get it to move until you feel it is to the right strength.
It helps to mention that too little is better than too much, as I see a good amount of people burnt out with their Compaq Evo & Presario (ca.2001-2) hinges, falling to the ground soon as you let it go, only 6 months after their last replacement set.
Nov 06, 2007 | Acer TravelMate 2300 Notebook
Dismantle Acer travelmate 270 Laptop
Caution is advised, as getting everything to work again after you put it back together is normally difficult, especially the screen. You will have to remove all the panels underneath, all screws and look for screws around the screen hinge area, with hexagon heads. There are no instructions on acer notebooks on their site for obvious reasons.
Mar 18, 2007 | Acer TravelMate 270XV Notebook
Computers & Internet Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
