Question about Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum
Turns on but does not want pick up anything.Suction is good but the garbage does not go into cannister.
  • 701 Answers
The reason it is not picking up is because the belt is stretched or worn. You simply need to replace the belt. you can get belts here:
Dirt Devil Belts
Posted on Feb 07, 2010
  • trish anne Oct 13, 2011
    what if the vacuum is only a couple weeks old? surely it's not the belt? I thought maybe I put it back wrong after emptyin it but it looks right
My dyson is not picking up, there is no suction its just blowing out warm air
Either the wind suction tunnels on top of the clear cannisters need to be cleaned out or the round foam filter between the bottom if the cannisters and the part with the roller bar is clogged.
Feb 26, 2018 | Dyson Vacuums
Dyson DC25 is barely picking up, but what it is picking up is not going into the cannister,
Your problem is posted in the wrong category, so probably no-one reading here (Telescopes and Binoculars etc) will have the solution.
I do know that Dyson maintains Tech Advice lines worldwide. Look here
http://www.dyson.com/
select your region, then look for a Tech Advice number you can ring
Jun 10, 2012 | Dyson DC25 Ball All-Floors Upright Vacuum...
No suction
there is a clog somewhere :) take the canister off and check the opening and the hose. sometimes items get caught in the top of the canister.. this greatly reduces the whirlwind effect..
Mar 28, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
Have a kenmore cannister vaccum, brush is working but it is not picking up anything the suction is not working ?
Remove the hose and clear any obstruction from inside of it. If that does not work check the bag and filter if one is installed
Jan 26, 2010 | Vacuums
There is no suction, even though the container is empty
Your hose is clogged and needs to be cleared. You may have to remove one or both ends of the hose that connects the dirt to the container.
You might have success trying to "back vacuum" the hose. A broom handle is sure to clear the clog, however.
Thanks for posting at FixYa.com
Dec 13, 2009 | Bissell 3576 CleanView II Bagless Upright...
No suction, again.
There is a blockage somewhere and its most probably jammed between the main dust channel between the beater bar and the bottom hose inspection. Remove the sole plate to see if anything is still stuck, check the beater bar as well and see if there is anything obstructing at the main hose removal point.
Mar 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum Logo
658 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
