Question about Acer Aspire 5610-4648 Notebook
Windows wont load all the way on my acer aspire desktop i need to reinstall from the partition ? how do i get the reinstall screen up
  • 617 Answers
Are you installing from a cd?
Posted on Feb 07, 2010
Erecovery management for acer aspire one without disk drive wont run
Ask acer for this problem, when you buy a laptop you need to make recovery discs, you prolly did not do that. So now it asks for recovery files on the dvd disc.
If it has no dvd drive you should have made them on a usb drive.
If acer cant help you with that, reinstall windows thats the only option.
Partitions hidden can be removed but then there is no way to restore the pc to factorydefaults anymore.
When you decide to reinstall windows, you will see 3 partitions, remove them all, then make 1 partition click next and it will make a little partition for system files. the rest is used for windows, untill u partition the rest, like a d: e: drive.
Jan 22, 2018 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire will not boot can you help
I think the operation system is corrupted and the action to do is press the key specified on screen to get to the boot menu ..and select the recovery partition if you have one ..In this option select to total reinstall the operation system and will work after that .
To engage the recovery if it does not work with the boot menu ..try to see if F11 works ..usually this key is reserved for recovery procedure alone ..
If you do not have a recovery partition you will need a recovery disk and the same procedure Boot from disk and reinstall the system or ..a Boot-able disk with operation system on it to reinstall the system from scratch ..
let me know if you have other issues related with this ..
Dec 21, 2011 | Acer Aspire X3810U1802 (PTSC102005) PC...
Want to Recovery the complete system on my Acer Aspire 0ne 110. How can i do that?
If you have the original "product recovery" CD-ROMs, re-install Windows from those disks.
Otherwise, is there a "recovery partition" on your computer's hard-drive? If so, then you can reinstall from that partition.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Apr 20, 2010 | Acer Aspire One PC Notebook
I have a acer AL5100-ud4400a i pressed alt+f10 while booting now im stuck on (verifing dmi pool data...... update success) nothing else happens any answers would be appreciated.
Huh, it seems to be stuck picking a boot device. Narrow it down by removing (disconnecting) USB, flash or optical devices, and see what happens. It might have been polling a failed DVD-ROM drive or something....
You can also try reseating your videocard or installing a lesser one until you get it booted....
Feb 14, 2010 | Acer Aspire L5100 Refurbished Desktop PC -...
Acer Aspire SA80 Desktop Locks up
Possible issue with recovery utility it might be corrupted.Try to boot computer using windows Operating system media. You might have to format and reinstalled Operating system if utility partition is corrupted
Aug 18, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
How to clean reinstall Windows XP and drivers on Acer Aspire SA20 AcerPower
Put XP CD in. Reboot. It'll load drivers and ask you on where to install OS. Delete ALL partitions on had drive, so if let say you have 80GB hard drive, your unpartitioned space ~79GB.
Apr 16, 2009 | Acer Aspire SA20 PC Desktop
Windows wont boot up
try to choose repair after you are booting from cd ...like you re-install it ...but choose repair at the second time ...after the system files are loaded ...after this ...just type the ..fixboot command ...or choose a command from the list by pressing f1 ( probably...there are guiding choices anyway...) my solution is to reinstall it ...and format the C partition ..its the safest way..and easier..one too..if you dont want to loose any data from this partition ..install it in the same folder first ..without format it ....move all data to D partition ..then reinstall a clean windows ..by formating the C partition...this will asure you a safe future run...
Mar 21, 2009 | Acer Aspire 3610 Notebook
Acer Aspire T180 PC Desktop fails to boot
You can use ERD commander to boot the system, backup your files to any other partition except first partition.
I am sure you have software related problem.
May 08, 2008 | Acer Aspire™ T180 PC Desktop
Acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
