Question about TDK Computers & Internet
My external TDK DVD 840G will not recognise disc.
3 Suggested Answers
  • 10406 Answers
SOURCE: TDK ded 840g
Look at the "back" of the device.
You'll see 40 pins (2 rows of 20 pins), 6 pins (2 rows of 3 pins), and 1 row of 4 pins.
The 40-pins is the "data" connection -- note that there is a "notch" centered in the plastic above the pins -- to ensure that the ribbon-cable can only be connected the _correct_ way.
The 4-pins is the "power" connection, note that 2 corners are beveled, again to ensure that the power-connector only fits in the _correct_ way.
The 6-pins are labelled: MA(ster) & SL(ave) & C(able)S(elect).
Move the small jumper to the 2 'CS' pins.
With the computer turned-off, connect the "data" and "power" cables.
Windows should "detect" this "new hardware", without needing a CD, and fully install the device.
Posted on Aug 23, 2010
SOURCE: I have an external teac
I think that Teac DV-28e Is a CD/DVD-ROM only, and will not burn discs. Teac DW-28e is a CD RW/ DVD ROM unit, and will thus play and burn CDs, but will only play DVDs. Check your model numbers to confirm, and then consider exchanging units if you need to burn CDs.
Posted on Feb 01, 2011
NEED A MANUAL FOR TDK+840G
what sort of problems are you having? Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jul 05, 2011 | TDK 840G indiDVD Internal DVD/CD Burner...
Won't recongise DVD+R dual layer 8.5Gb TDK DVDs.
Most of the drives are not capable of recognising specific color medias (specifically purple), try using perl, silver media for dual layer disc
Jul 17, 2010 | ASUS DRW-2014L1 DVD±R Dual Layer Burner
Disc error
Ive bought some tdk mini discs dvd -r for my samsung camcorder and some of them work fine but I also keep getting disc errors on a lot of them when Iput them in?
Apr 03, 2010 | Samsung SC-DX103 DVD Camcorder
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Compatible dvd-r discs?
I've never had much luck with DVD-R's but the DVD+R's that I've used work just fine; Verbatim and TDK have both worked.
Jan 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
Cannot remove protection to record
Have you tried playing the tapes in an 'older' player' that doesn't recognise the 'CSS' and then into the Panasonic DMRES 30V through the 'input' side? That should work.
Oct 16, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
DVD disc recording
Certain disc only work in certain recorders - I know this sound weird but you must find the disc that is compatible with the recorder that you are using. If the TDK discs is working continue to use the TDK discs. Even though the format and the specifications are the same on both disc, the readers does not read all disc.
Mar 29, 2008 | Televison & Video
I cannot get TDK CD's to laser-etch.....
Hi check the disks closely, you may have bought DVD disks by mistake.
A normal CD will not recognise a DVD disk.
Regards mistyman
Feb 12, 2008 | Computers & Internet
BURNING DL DISC WITH NERO
G'Day,
I have the same issue with the LG GSA-H20L and the LG GSA-42N, but mine was with TDK DVDs.
I contacted LG Support and they told me that TDK disks are not recommended for use with their DVD Burners.
I asked them if there were any others they did not reccomend and they said no.
Going through my cupboard, I found Memorex Printable DVD-Rs that will burn OK.
I also tried Sony DVD+R and a generic brand, but they will not burn either.
I also found that these LG drives do not recognise Laser CD-R.
In short, for burning, try either Memorex, LG and some others, but don't try TDK, Sony or Laser.
Good Luck
Jan 13, 2008 | LG GSA-H42N 18xDVD+-R, 12xDVD-RAM,...
Computers & Internet Logo
59 people viewed this question
Top TDK Computers & Internet Experts
David Payne
David Payne
Are you a TDK Computer and Internet Expert? Answer questions, earn points and help others
