Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
The ice maker comes on ( you can hear it) but no water goes into the icemaker. But there's a water spout on the outside of the frig that shares the same water line, and water does come out for drinking
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems that the water inlet valve has gone bad and needs to be replaced. To start with you can check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
How to remove icemaker from whrilpool ultraease refridgerator
I had a simular problem with my Whirlpool frig--First of all I would check 1/4 inch plastic line coming from water valve up to ice maker,loosen this line & try to blow thru it -if there is an obstruction it probably is frozen inside plastic fitting at top where it goes thru cabinet & into ice maker if so you can melt by by running a very warm metal object up & inside fitting be patient, you need to both inside & outside--If this the problem,your water valve is probaly bad because of not shutting off properly causing the "drip effect" you can purchase valve on line for aprox $10.00--$25.00 Good Luck--John Morris--
Feb 08, 2013 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
U-Line Icemaker is cold, but no water in resesrvoir for the ice.
Your water valve may hay a drip like a faucet. Causing the spout to freeze up.
Jul 08, 2012 | U-Line Icemaker
Water not coming up to icemaker
With ice makers it is almost always one of two things. The ice maker itself, or the water valve (valve is located on the backside of the frig, bottom right hand side almost 100% of the time). Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
Quick facts: If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker. However, if you still get water through a dispenser (if you have one) then this cannot be the case.
May 23, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice make has stopped making ice
Try filling the icemaker with a cup of water where the ice is made. Make sure the shut off arm is up. wait like a day. if it does make ice then you water valve needs to be replaced. if it doesnt replace the ice maker. also dont forget to check the tube behind the ice maker. it feed the icemaker with water. if that freezes up then water cant make it to the ice, thus ice maker and valve are fine. get behind the frig at the upper top right behind where the ice maker is but outside back. there is a tube that can be pulled out that is the feeder tube make sure no ice, do this ok?
Mar 27, 2010 | Refrigerators
The water isn't coming out of the spout on the ice maker. The ice is working, just not the water.
Sounds like you have a bad water valve. Look and see it the spout where the water comes out to fill your icemaker has ice in it. If so, you have a seeping water valve.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a whirlpool refg. with built-in ice maker model# ED25DQXDW02. Everytime the frig. goes to fill the tray it fills it then over flows some. Is this a problem I can fix myself.
probably have to replace the icemaker take it out and look at the mold and see if you have some teflon coating that has come of and or some water deposit buildup under im on heater on bottom of icemaker. this causes it to let the water drip down on the back of im an causes iceblock in the dispenser bucker. you can order an icemaker 1- 877-262-1479
May 27, 2009 | Freezers
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
No Ice & no chilled water from frig.
First off does this model have a water filter if so...and if it is old and or full of filtered material the water will not dispense anywhere.
Ok...the way to test for power is obviously with meter you can easily check the solenoid leading to the inside of the frig by exposing where the connectors attach to the solenoid...but do not remove them completely you should have a continual 110/120 v supply...someone at the front of the unit can depress the dispenser and you will hear the solenoid activate...if it does not...the same should apply for the ice maker solenoid...unless it is activated by the timer (electrically) and not mechanically (which it usually is) if you are getting voltage to both of these....and you have voltage to the primary solenoid...(which you may not) if you do not have a filter...and both of the other valves stopped working at the same time..(which would be rare). Then there may be an electrical problem in general. Also you can check to see if the firdge is cold enough to make ice by manually filling the Ice maker with water...it should freeze in under 4 hours and dump the ice also...if it does...them it lies in an electrical problem in general or electrical problem to the primary solenoid. Also do you have hard water....as it may be posible for calcium deposits to accumulate at the valve inlets...and often there are tiny screens in place here also. Check for water continuity at the valves if possible.
I hope this helps....good luck and get back to me and we can go from what you find out.....please rate me.... the Fang
Mar 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
11 year old amana frig icemaker
you most likely have a short in the ice maker ..the ice should be ejected before the water is call for... you need a new ice make or if you can change the ice maker head let me know and I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
