Starting laptop screen has colours bur can't see picture
When screen first had problem if you put pressure on bezal in certain places images would reappear when held,(screen where you put in password) but now colour is there but no images at all (running vista). I connected external screen works perfectly so my question is how do i know if it is lcd or inverter board or both thanks?.
  • 3 Answers
I dont know
Posted on Feb 07, 2010
6 wires for heating element. The labels fell off so I don't know which go to which terminal. Images on google show different wiring so don't know which is correct.
If you use wrong terminal, you might bur out your thermostat and even your dryer,
If you don't know how to connect it, call an electrician who should have an electronic tester to tell how to reconnect wires
Aug 16, 2015 | Dryers
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 ยต Digital 820...
Thin vertical colour lines on half of the screen
Hello, there is a problem with your monitors picture tube. May be it might have been damaged as a result of over power or even because of over use. Just try to change the picture tube or change your Monitor.
Nov 15, 2017 | Samsung SyncMaster 910MP 19" LCD Monitor
Blotted screen in my hp laptop
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
Sep 19, 2011 | Computers & Internet
Laptop screen
try to figure out what the picture says than go from there.
if you cant see the picture, than go into the screen section of your laptop and than try to up the colour in the boxes there.
Jul 27, 2008 | HP Pavilion dv1000 Notebook
PRINT COLOUR IMAGE FROM GOOGLE IMAGES
getting vertical lines on my pictures . i have a epson cx5000.
Jun 08, 2008 | Epson Stylus C66 Inkjet Printer
Multic coloured screen
12b809f.jpgHere is what my pics look like. It was a progressive defect, some good pics, then these in between. Now they are all bad. I found this info below... even though the SP350 is not listed, I am going to call Olympus tomorrow. Good luck!
The camera takes blank images, or the image is distorted
  • There are a number of digital cameras models sold by Canon, Fuji, Konica-Minolta, Nikon, Olympus, Ricoh, and Sony (and possibly others) which use CCDs (image sensors) manufactured by Sony which have had a high rate of failure. Details can be found at http://www.imaging-resource.com/NEWS/1128958202.html
  • Most manufacturers will replace defective CCDs affected by this problem at no charge, regardless of warranty status. This service advisory (technically, it is not a "recall", since recalls are related to safety issues) only applies to certain models and certain serial number ranges.
  • If your camera exhibits the symptoms listed above, we recommend following the link or calling Olympus Customer Service at 800-622-6372. We do not replace the CCDs in Camedia or Digital Stylus models.
Nov 12, 2007 | Olympus SP-350 Digital Camera
Colour problem on rear projection tv
This might be something really simple... In a large number of DPTV310 chassis, of which this TV is, the yoke connections where put in place with black electrical tape just below the retaining rings. Job is to loosen the rings, remove the tape and push the yoke back in place and tighten down retainer.. Be careful not to throw off the tilt of the yoke. The adhesive on the tape, over time, gets hot so many time it becomes slippery and allows the yoke to fall away from it's position dulling the look of the image (or focal length) causing the problem you're describing here... It also throws off the convergence - so in attempting to converge it just looks worse. Good Luck Bill
Jun 10, 2007 | Philips 60PP9352 60" Rear Projection...
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
