Question about GE Profile PFS22MBS Bottom Freezer French Door Refrigerator
We have a GE Profile refrigerator Model # PFS22MBSBWW. We have replaced the condenser fan motor, the mother board/ main control board and the refrigerator/ freezer is still not cooling properly. The refrigerator is cooling better than the freezer. Any suggestions?
  • avvalora Feb 07, 2010
    Thank you for replying so quickly. Okay, husband says the refrigerator is still clicking like it was before we replaced everything. Also, how would he check the divertor doors?
  • 4,369 Answers
You are either low on refrigerant diverter doors are not sending enough cold air to the freezer. I think low on refrigerant.
Posted on Feb 07, 2010
  • gerry bissi Feb 07, 2010
    there are several air vents in the back of the refrigerator that blow cold air into the fridge side. WHen fridge is cool enough, the vents modualte or colse and divert cold air to freezer. Fridge should be set at 37 degrees F and freezer at 0 degrees F.
    If the air is not cold enough, it means your compressor is kicking off too early or low on freon. If you hear a relay clicking rapidly, it could be low on refrigerant.
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
I have a freezer on top GE profile arctic fridge. It heated up for 24 hour then went back down and is now hovering at 7 freezer and 42 fridge. What is wrong?
This is a common problem with the GE Artica and Profile. The mother board=> WR55X10942 Main Control Board Compressor start components and condenser or evaporator fans must also be considered in the diagnostics. If you would like to do this yourself let me know and I will be glad to help you go throgh with the testing, Thanks Sea Breeze
7_10_2012_2_44_57_am.jpgWR55X10942 Main Control Board
Jul 09, 2012 | GE Profile Arctica Stainless Steel Top...
I have a ge sbs model pcp23shmffbs. the condenser fan motor is running slow, but turning freely. the fan motor is rated at 11.3 volts dc and supply to fan motor is only 6.7 volts. is the condenser fan...
If the motor is running, but running slowly, you will need to replace the motor. If there was a problem with the PCB, (control board) the motor would not run at all and you would see other problems with the refrigerator.
Here is a link to the motor.
Jan 28, 2011 | GE Refrigerators
Model psc23sgpass GE Profile freezer and frig do not get cold enough. I have already cleaned the condenser and defrosted the freezer. We seem to have determined the evap dc fan motor is not running. But I...
The fan is controlled thru the main control board located on the back of your refrigerator. Pull unit away from the wall and you will see a metal plate. The board is located there and you will need to replace the board. This is a common problem with the GE's. The board is pricey but better than a new refrigerator. If an appliance company told you the fan was bad you should try and get them to refund the fan. wr 55x10942 is the number you need.
May 28, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Got a ge profile seems the fz fan motor is not working..it's intermitinng..ya think it's that mother board?
Could very well the main board as it controls the fan speed be I have found several where the fan will only run on certain speeds
Feb 16, 2010 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Coil fan will not run.
Replace the master control circuit board on the rear of the fridge.
Jun 22, 2009 | GE Profile Bottom-Freezer Refrigerator...
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile PFS22MBS Bottom Freezer French Door Refrigerator Logo
220 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
