Question about Kenmore 64722 Electric Dryer
Dryer will not heat and timer does not move - Kenmore 64722 Electric Dryer
  • 10,319 Answers
If the timer does not move the timer is broken. replace it and your heat will be restored again
Posted on Feb 07, 2010
Testimonial: "very good thank you very much"
  • 27 Answers
SOURCE: Electric Dryer problem
the timer has a small motor to advance the timer. the motor is the likely problem. on some old maytags you can get just the motor, but you probably will have to replace the complete timer. hope this helps.
Posted on Nov 02, 2007
Maanita
  • 1142 Answers
SOURCE: timer doesnt move while dryer is on
Please page me here so that i can get back to you
Posted on May 19, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Dryer LER7646EQ1 Not heating
If your drive motor is turning, but your timer and heating circuits are not working, it sounds like you could be missing one leg of your 220 service. The dryer timer and heating circuits utilize the full 220 from the receptacle, while the drive motor only uses 120 VAC. Unplug your dryer and check the voltage at the wall receptacle. You should read 220-240 VAC across the two hot leads (these are the two large slots). The wires are BLACK - L1 & RED - L2. If you only read 120, check each slot to the NEUTRAL slot (white wire) to determine which one is missing. Chances are, you may have a break in the L2 (red wire) line. Here's the wiring scheme depending in which type of power cord you may have:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Please doublecheck and let me know. If your source voltage is correct, perform continuity checks from the end of the power cord to the terminal block in the back of the dryer. Inspect for any burned or broken wires. If you are not able to isolate a problem at this point, please post back and let me know. I can assist you further. I hope this helps.
Posted on Aug 13, 2008
TheMobilian
  • 8220 Answers
SOURCE: My Kenmore dryer (model # 11077732795) would not
Just inside the drum on the front panel is a metal sensor strip that detects a change in capacitance as the clothes get dryer. When no more dampness is read the motor is energised by the moisture sensing board. Get the goop off the sensor strips so they can send a dry message.
Posted on Mar 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Posted on Apr 10, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Timer will run dryer but does not time
if the dryer has no heat the timer will not move on auto,when the heat shuts off the timer moves,when the heat comes on the timer stops,it will do this until clothes are dry
Oct 08, 2010 | Kenmore Dryers
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
Dryer will not turn off is it the timer? the dial does not move
do you have heat?when the dryer heats up the timer doesn't move,when the heat shuts off the timer moves,when the heat comes back on the timer stops,the timer will not move if there's no heat.if you have heat it could be the timer.also run the dryer when it's cold for 15 to 30 minutes and check to see if the flame is still liting,there's a little cover on the front panel that you can pop off to see the flame,there's a set of gas coils on top of the gas valve that when they fail they will stop working when they heat up,when the coils cool down they will let the gas through and the flame will lite again,common problem with gas dryers and most likely your problem.also when was the last time you cleaned out the dryer,you need to blow out the vent line if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the line,make sure the outside vent is clear so the air can blow through,next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year moreso with gas so you don't have a fire,also your clothes will dry on time and you'll have less problems with the dryer.let me know what you find.
Apr 18, 2010 | Kenmore 73952 Gas Dryer
My drum on my dryer rolls but there is no heat and my timer is not working...what could it be??
the timer will not move if there's no heat.when the dryer starts to heat and then shuts off then the timer will move when the heat starts again the timer stops.you need to send the model number is it gas or electric?you might need to clean out the dryer and popped the thermal fuse from the dryer running to hot or you have a bad heating element or ignitor,you need to get in there and start checking parts to see why you have no heat.
Apr 18, 2010 | Kenmore Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
Heats take long to dry and timer won't move
The timer not moving means that the timer has gone bad. The heating problem may have to do with the timer too. You can take off the vent tube of the dryer and make sure it is not restricted (from dryer to outside) If this is plugged it will also take longer to dry your clothes.
Feb 10, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore 64722 Electric Dryer Logo
98 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
