Question about Oster 5838 ExpressBake Bread Maker
Oster 5838 breadmaker
Will the boxes of permade breadmachine mixes work in this machine?
Yes. I have tried several mixes & all have come out just great. The box usually has instructions on the order to put your ingredients in (so follow that). Yeast first, then mix, then liquids on top. I've even set mine up for delayed baking & they came out well too. Good luck!
Posted on Feb 02, 2009
MY OSTER 5838 EXPRESSBAKE BREADMAKER MAJES HORRIBLE GRINDING SOUNDS WHEN MIXING
You may have a bearing problem causing the grinding noise or the motor stator is rubbing on the housing
Jan 01, 2012 | Oster 5838 ExpressBake Bread Maker
My Oster Bread machine is not mixing, it is installed properly
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Tip: The belt and pulley assemblies are located at the bottom of your breadmaker.
Hope this helps!
Jun 13, 2011 | Oster 5838 ExpressBake Bread Maker
Lost manual to bread machine need another one
Hi
Thanks for using FixYa. You can download the user manual for your breadmaker from this link--
Oster 5838 ExpressBake Breadmaker Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 30, 2009 | Oster 5838 ExpressBake Bread Maker
Oster 5838 and a good banana nut bread recipe
CookingCindy 1 Solution July 23, 2009 I have made the following recipe in my West Bend machine with great results. I just got a Sunbeam 5895 at a garage sale - it works great - just wanted a different "shape" loaf! I'm going to use this recipe in my Sunbeam - don't see why it won't work! Here's the recipe! 1/2 cup softened butter, cut into small pieces for good blending 1 cup mashed ripe banana (personal note: if my ripe bananas don't measure up to 1 cup, I add enough milk to make it 1 cup. Seems to be okay) 2 eggs, large, slightly beaten 1/2 cup chopped nuts (optional) 2 cups all purpose flour 3/4 cup sugar 1 teaspoon baking powder 1/2 teaspoon baking soda 1/2 teaspoon salt Grease inside of pan and knead bar generously with vegetable shortening (I just spray with Pan Spray). All all ingredients in order listed above to pan. Lock pan into bread machine. Program for quick bread. After a few minutes of mixing, I usually take a rubber spatula and scrape down the sides and stir in any flour that has not been completely mixed. I didn't do this once and ended up with a loaf that had flour coated corners! Good Luck! Enjoy! Just follow the above recipe but if your using the Oster 5838 expressbake put the setting at expressbake 80min. It works flawlessly, also with the oster 5838 expressbake you don't need to use the rubber spatula to mix after a minute because it blends everything together nicely. Thanks bobert.
Jul 13, 2009 | Oster 5838 ExpressBake Bread Maker
My new Oster 5838 breadmachine: The bread pan will not come out.
you have to twist the handle a little and oull hard! it will come out, good luck
Dec 13, 2008 | Oster 5838 ExpressBake Bread Maker
Oster breadmaker model 5814
I just bought a pan and paddle from ebay and I do not need the pan. I can see it to you if you like.
Mar 04, 2008 | Oster 5838 ExpressBake Bread Maker
Oster breadmaker 5815
Hello, Here is a link to a 5814 unit manual. It may be very close to what you are looking for - Good Luck! Dr. Know
Nov 29, 2007 | Oster 5838 ExpressBake Bread Maker
Oster 5838 Breadmaker
The biggest thing is the yeast. If it's even a minute past due then throw it away. Freshest is bestest. Also watch your water temp. not to hot, or too cold. Warm enough to your touch.
And make sure your yeast is in your little well on top.
Oct 28, 2007 | Oster 5838 ExpressBake Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
91 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
