Question about Jenn-Air Kitchen Ranges
I am replacing the oven element on my jenn-air 88370 range. There are 2 lines that come into it and I thought I had replaced them the same way as they came off, the 2 blues to the right or left and the brown to the center. However now the breaker either trips when I turn on the oven or there is a spark and smoke from the oven light switch, at which point I turned off the breaker myself. How do I fix this or test it to know which wires go where?
  • gabyzphd Feb 07, 2010
    Yes there is an actual connection point on the bracket between the two posts of the element itself. I did some more testing and the brown wire is hot. When I turn the selector to bake the brown and blue complete the circuit and when I turn the selector to broil the brown and greenish complete the circuit. Knowing this I don't know which wires to connect to the element and which to connect to the bracket.
  • gabyzphd Feb 08, 2010
    I have actually looked at the wiring diagram. If you wouldn't mind here is a link to it: http://forum.appliancepartspros.com/oven...
    To me it looks like the brown and yellow should go to the element with the blue going to the fan. Does that look correct to you? If it does I have it hooked up correctly and there are further problems which are above my paygrade. Thanks for any further help or comments.
    Genius:
  • 1,036 Answers
Oh dear.
With the breaker off and cooker switch off, test the elements with an ohm meter to find which is the common. I suggest this is the brown in your case.
Use the oven selector switch turned on as normal - and use a continuity tester between the connector to one element (blue), and one of the supply wires (check it is off again)
Then select the other element with the switch, and you should loose continuity, but testing the other blue contact should get continuity again.
It is possible that you are replacing an element - but the original problem is centred around the switch.
It's easy to jump to conclusions and replace parts - leaving the original problem, Garages do it all the time.
Posted on Feb 08, 2010
  • 291 Answers
You probably hooked your wiring up correctly. Quite often, when an oven element first blows out, it will also take out your Oven thermostat, Oven selector switch, Electronic Range Control, or wiring. The fact that there is a spark and smoke from the oven light switch tells us that you have a short somewhere. You will need to get into your control panel and visually look for burned terminals, wiring, ect. If there is anything obvious, you can replace it, however the best way to make sure that there are no other problems that can burn out new components is to use your wiring schematic to test your different components. This is quite a bit more involved to diagnose than a bake element, and involves testing the different wiring terminals with the electricity on. If you are comfortable doing this, and know how to read a schematic, then go for it. If you are not sure what you are doing, don't touch it, there is 240 volts there, enough to kill a man. Call a service man to diagnose the rest of this repair. Good Luck, Appliance Specialists
  • Norm Dickerson Feb 08, 2010
    I just read your second post. You are going to have to find your schematic for this. Check behind the drawer, or access panel in front. Can be behind control panel or on the back panel. Green is usually always ground, which should be the middle terminal on the bracket, but without your schematic, there is no way to be sure. Good Luck, Appliance Specialists
  • 476 Answers
Did you disconnect the light receptacle by any chance? I show a yellow and the brown wires going to the lower element and the blue going to the light receptacle, when you connect the brown to the center, what exactly do you mean, is there an actual connection point there? that could be why the braker is triping.
Posted on Feb 07, 2010
I have a jenn air model jer8850aaw replaced the bottom element and now the element will not shut off what could be the problem?
If the element wont shut off sounds like the oven thermostat control made be faulty, if its a manual knob you use to turn the oven on you'll need to replace it, but if its electronically controlled you'll need to replace what the call the erc or clock.
Oct 31, 2010 | Jenn-Air JER8850 Electric Kitchen Range
Jenn Air Range Model 88370 oven only bakes in the back and leaves food raw in the front.
It will be the oven element that has failed, a new one wiil need to be fitted.
It is located at the rear of the oven compartment behind a removeable cover.
I hope this helps.
Apr 11, 2010 | Ovens
Instructions to replace Jenn Air oven thermostat
To remove the control panel, open the oven door wide as possible. Remove the screws from the top of the CP and the screws from the bottom of the CP. Grasp the CP bu placing hands on the right and left sides of the panel, pull out and down to disengage. Depending on manufacture run you might need to lift up and out to diengage.
Have a cloth on the oven rack to lay the control on so you won't scratch the pretty facing. Once that is done you have easy access. Wear some rubber gloves doctor, this prevents harm to the electronics. Static discharge is a no no around expensive electronics. You can do this. Take your time. Piece of cake.
You will be able to check high limit cooling fan door latch and motors 9if applicable on your model) cool ain't it?
Jan 07, 2010 | Ovens
My oven heating element doesn't get red and the oven temperature rises only until 270 degrees. The broiler element works fine. Any thoughts?
I removed the heating element and checked it with an ohmeter, which showed the element had shorted out. I've purchased another element on line.
Nov 21, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Installing Jenn-Air 88370
Jenn-Air.com/ Support online can help you
Apr 22, 2009 | Kitchen Ranges
Accel Cleaning Setting
It's 'sort of' self cleaning. I just got done figuring it out. If your clock still works, you're supposed to set it for one hour of cooking. Turn the Selector to Accel Clean and the thermostat to 550. The oven fan should come on and the elements should heat. The door doesn't have a lock, which must explain why it only 'cleans' at 550°F.
Jul 28, 2008 | Kitchen Ranges
Jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Jenn-air oven model #88370
its just not that often the probe fails without setting a code
Feb 16, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Oven element
bad relay on erc(electronic range control), or and open thermaostat wired in line with element you would need to pull unit and check wiring
Feb 07, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Kitchen Ranges Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
