Question about RCA P52939 52" Rear Projection Television
UNIVERSAL REMOTE WILL NOT WORK - RCA P52939 52" Rear Projection Television
Universal remote need codes for Baird X32DTV as the codes the universal remote came with don't seam to work?
If a code search using your universal remote did not work, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jul 07, 2016 | Universal Televison & Video
Will any universal remote work with my Akai Model CFT2790?
Hello there
YES !!!!
Do you simply HAVE to have UNIVERSAL Remote?
For this TV the correct remote is here for 10 American dollars. http://www.replacementremotes.com/AKAI/Buy-10111J-AA5910111J-TV-Remote-Control.html
On the other hand if you must have a universal remote, then it WILL work with remote code for Akai which is 002; See the instructions with the new Universal remote.
Obtained from here http://en.kioskea.net/faq/281-codes-for-universal-remotes#universal-remote-codes-by-brands
Sep 19, 2014 | Akai Televison & Video
BLUESKY
Hi, each TV has its own specific set of codes it uses. But regarding universal remotes and programming them they are all different. universal remote manufactured by "one for all" might have the working set of codes for your TV under code 1234, and universal remote "RCA" might have the working code for your TV under 987. so the code depends on the universal remote you are using.
So we need to know the brand and model number of your universal remote you are programming to find you the correct code. And even if we do find the correct remote and manual for your universal, there is a big possibility that the universal remote will still not work.
Nov 30, 2012 | Televison & Video
Can a universal remote work on my sansui sv2002
Universal remote codes for Sansui TV are: 0135 0310 Just buy one universal remote control, which have these setup codes for Sansui Brand TVs with its code list. Code list will be attached with the remote control packing.
Oct 26, 2012 | Televison & Video
I have a soniq 42"
Ah, the old universal remote isn't so universal anymore is it? Most "universal" remote controls were designed for the old tube type television sets. There are some seriously nice universal remotes for new flat screen TV's, but most of them are pretty pricey. The only reasonable flat screen universal remote that I've found (that actually works) is the Vizio HDTV Universal Remote. It's about $25, and believe it or not ... Wal-Mart carries it in the store.
May 16, 2011 | Televison & Video
I bought a used GE TV at a resale shop. It didn't have a remote with it though. I bought a universal remote and it doesn't work for it either. The universal remote does work on another tv in the house...
i would buy an GE Universal Remote. Any GE Universal Remote will work with any GE TV's. Just like a Magnavox Universal Remote will work with Magnavox without programming it.
Mar 05, 2010 | Televison & Video
Can you use a universal remote to program Philip
can a universal remote work on a protron dvr recorder
Feb 18, 2010 | Philips Magnavox Learning Universal Remote
Remote is no longer working
i need a universal remote that can work for a jwin dvd player
Feb 03, 2008 | Jwin JD-VD502 DVD Player
RCA P52939 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
