Hello, Justin.
If you are using all the devices (3 xboxes and 1 computer) all the same time, your signal strength will be weaker, since you are dividing the signal.
So, power one or more devices off (not just logoff) if you are using the others.
Hope this helps.
You may have to change the ip address of one of you systems. Sounds like one is interfering with another. You can change it in system settings.
In your system settings, there should be an option to change your connection settings. From here, make sure everything is set to automatic. Then you should have to adjust anything. Then unplug just the router's plugin for exactly 10 full long seconds, plug back in, wait 3 minutes and try everything again to see if it works.
That is possible if you don't have a very high rated router. I suggest N series or G series. I run 2 xbox 360's 1, desktop and 3 laptops off of our belkin router I got off of amazon.com for $40. N series is the newest and fastest router connection
How do i do that?
how do i do that?
already did that still poor connection. I think it is just running to much off one router
