Question about Verizon Communications Samsung Alias Cell Phone - Black
The charger is in the charging port but it wont charge
My alias 1 has a charger that isnt the original, but used to work, now however doesnt, what should i do??
  • 92 Answers
SOURCE: env2 charger wont fit in the hole and wont charge my phone
is it the right charger? if it is it may not be fitting good because the charger might not be good or the charging port on the phone take it to a verizon store.
Posted on Dec 16, 2008
praky16
  • 744 Answers
SOURCE: wont charge please helppp me i will help youuuu
hi
try to change ur charger pin.. it would have got damaged...
thank u!!!
Posted on May 01, 2009
GrinningFool
  • 625 Answers
The issue is the charger port on the ENV2 breaks fairly easily. The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars.
2. you can get a new phone. cost ???
3. you can get an external battery charger to charger battery separate from phone. cost about 25 dollars. check out the following link for ones that are available on ebay. LG VX9100 ENV2 External Battery Chargers
Posted on Jul 02, 2009
GrinningFool
  • 625 Answers
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
Hope that helps
VinayT
  • 1884 Answers
SOURCE: SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Posted on Aug 05, 2009
Galaxy wont charge even though hit shows that it is?
Not sure if u have insurance warranty. But Galaxy phones have a known charging port issue. I have gone thru many of these phones. I also own one I modded a new charging port and it works great. So Imo I would say cheap parts installed. But if you have never done a soft reset yet try that first. But do the soft reset (5) times. In a row. Then plug it in. Hope you got it solved either way.
May 19, 2014 | Samsung Galaxy S GTI9000 Smartphone
Phone wont charge
try to use a other charger
or reset the phone
if it wont work try a other battery
if that doesnt work then you have to go to a phone shop because the charg port is broken
Nov 23, 2009 | RIM BlackBerry Bold Smartphone
Ipod doesnt work
I think I know just the problem. The connection cord that came with the wall outlet charger can only be used for charging. You have to have the original apple cord in order for the computer to recognize it.
I had the same problem.
Sep 20, 2009 | Apple iPod touch
My alias won't charge
Unfotunately, this is a common problem. The first thing you should do is take it to the Verizon store(or someone else with the same charger) and ask them to try a charger. Hopefuly you can just buy the new charger. If this isn't the case, and normally it isn't, you will have to buy a new phone or dish out the 50$ for insurance if you have it. The problem is that you broke the charge port in your phone. Samsung considers this to not be under warrenty. The Verizon store cannot do anything for you. Hope this helped.
Sep 17, 2009 | Verizon Communications Samsung Alias Cell...
My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Jun 12, 2009 | RIM BlackBerry Pearl 8100
Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
May 30, 2009 | Samsung SCH-u740 Cellular Phone
Battary
It Prompts when Battery Low -
But U Havent Looked at it -
U Just might have put it to Cable to charge -
But it doesnt -
So Means u have to change Charger -
Be See that ur Charging socket isnt Loosened -
Then change ur charger with a Newer n Original
One -
Jan 20, 2009 | Cell Phones
Env2 charger wont fit in the hole and wont charge my phone
Dec 16, 2008 | Verizon Communications enV2 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Zen vision M wont dock
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Oct 08, 2007 | Creative Labs ZEN Vision:M Digital Media...
Verizon Communications Samsung Alias Cell Phone - Black Logo
137 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
