Question about HP Pavilion dv6000z Notebook
Laptop turned off due to low battery. won't turn back on even when plugged in
  • 90 Answers
Try to remove your battery and plugged in only your power adapter. if its turn on its OK.but try also to charge the battery at 100% without using it. I think that it may be your battery which may caused this problem.
Posted on Feb 07, 2010
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Laptop died out due to no charging.. but now even when its being charged, it wont turn on
The battery may have gone bad. Amazon is one of the cheapest places to look for a replacement.
May 08, 2015 | ASUS Transformer Book Flip TP300LA...
Computer won't turn on help!!!!
Unplug, remove the battery, plug in, try to turn on. If that fails, try another AC/DC cord/charger with the EXACT same power specs. Has the AC jack been damaged due to pulling on the cord? Damage due to Power surges? Do you leave it plugged in while not in use a lot?
Apr 13, 2013 | Computers & Internet
No Power
Your laptop's power jack may be broken, which is why your laptop doesn't charge your battery at all, which is why it won't turn on now. I would take a look to make sure that the power supply is good, the battery is good, and then see if the power LED is even coming on when you plug the laptop to a power source.
Apr 10, 2013 | Gateway Computers & Internet
Acer aspire 5736z-4460 won't turn on
tried to remove the battery and then re attached, turn on the pc laptop check if it works.
Aug 03, 2012 | Acer Aspire 5736z 4460 Laptop
Ran 99 chevy express hot won't start even with a
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 19, 2012 | 1999 Chevrolet K1500
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Wireless not connecting when 6930 running on battery rather than mains. This is apparently due to low signal strength, or no response from the router, but with the main plugged back in it connects again.
This is due to the power settings of your wireless adapter.
Right-click "My Computer" and choose "Manage". This opens the Computer Management console.
Go to "Device Manager" and find your wireless adapter.
Right-click and choose "Properties".
One of the tabs should have a "Power Management" setting, which says "Allows the computer to turn off this device to save power".
Uncheck this option, if you don't want your computer to turn off your wireless adapter when running low on battery.
Dec 17, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
HP Pavilion dv6000z Notebook Logo
53 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
