Question about Grohe Model 28 206 OOO: Ladylux Plus Deluxe Champagne shower head - Chrome
Hello: My Grohe Lady Lux Cafe kitchen faucet has become loose where is it attached to the sink. How do I tighten it back up? David
    Guru:
  • 1,051 Answers
You'll have to go under the sink and look up were the faucet comes through. You'll see it's held in place by a large nut. This nut needs to be tightened. Unfortunately working in the tight space under the sink is a pain in the ****, just be patient and you should be able to tighten it. TIP: Have someone hold the faucet on top in the position you want it.
Posted on Feb 07, 2010
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
The faucet is loose on the sink how do i tighten it?
if you look under the sink at the bottom of the tap there should be a long threaded screw with a nut fastening it to the sink by a curved metal bracket and a rubber washer,( try tightening this.)sometimes the bracket and washer corode if they have then you will have to replace them
Aug 17, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
How to tighten to sink after install?
the faucet comes with two plastic nuts once you set the faucet into the sink you have the 2 supply male lines use the plastic nuts to attach the faucet to the sink and tighten by hand
Jun 08, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
May 22, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
I have a water pressure problem with a Grohe Lady Lux Cafe faucet
I solved the problem by unscrewing the part of the handle which attaches to the "pullout" braided cord. There was another strainer in there which has some debris which was blocking the water flow.
John Was.
Nov 16, 2008 | Plumbing
How to take handle off of Grohe Lady Lux Cafe-took screw out-handle is stuck
I soaked the connection between the handle and the valve body in a penetrating oil for several hours and eventually used more force than I hoped to use to remove the handle. Once the handle and end cap (part 09 209) were removed, I could see that the valve assembly (part 46 048) was loose which caused water to leak from the seals (part 46 209) between the valve assembly and faucet body. So I tighted the screws that hold the valve assembly to the faucet body and the leaked stopped.
Oct 11, 2008 | Plumbing
Grohe Model 28 206 OOO: Ladylux Plus Deluxe Champagne shower head - Chrome Logo
448 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
