Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
65 Toshiba picture sides are bowing in.
I own a 5 year old toshiba cinema series 65 rear projection tv. this morning I noticed that the picture appears to be bowed in from both sides and I see more blue on the left side and more red on the right side. Nothing occured near the television to cause this.
  • capecoder Feb 21, 2008
    I appreciate the response but I looked at the examples and mine looks nothing like them, the picture is still viewable but the outsides are bowing inward in an arc it almost looks like an hour glass on the outer edges
  • Vista Electronics May 11, 2010
    Have you researched horizontal pin output failure ?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Feb 21, 2008
  • Cary Farah
    Cary Farah Feb 21, 2008
    see if your set has the stk392-xxx ic's in them i think it's the same problem just looks different.
I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
May 28, 2012 | Toshiba Televison & Video
Toshiba Rear projection 65" cinema series
You need to replace or have the convergennce IC's replaced. This is not a very hard job to do, but will take some soldering skills. Good Luck
Oct 21, 2007 | Toshiba 50A61 50" Rear Projection...
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
My Toshiba 65H81 65" rear projection TV's picture
You do not have individual lamps in that model. You have 3 individual picture tubes of which I don't believe they are bad. They have fluid in a reservoir that becomes cloudy after time and needs to be replaced, however this is something you cannot do yourself. I recommend you call a qualified technician to take care of it for you.
Nov 26, 2010 | Toshiba 65H81 65" Rear Projection...
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Toshiba 53AX61/ have sound no picture
I have the same problem with the same Toshiba 53ax61 the picture does not work anyone,
Please email me at skyhawkbasketball@hotmail.com
Oct 09, 2007 | Toshiba 53AX61 53" Rear Projection...
Toshiba Projection Picture discoloration
burn in on one of the tubes try magic focus?
Mar 12, 2007 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
299 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
