Question about Sony Handycam CCD-TRV308 Camcorder
When turned on the camera beeps and flashes C:31:22 ?
What is error C:31:22
    Problem Solver:
I had a the same error mesage, resolved it aftr some research, just remove the battery & smack it down harder, on a soft surface though,keep samcking, try ejecting u mite have to repeat it a few time, it will resolved it, i resolved mine just today
Posted on Jun 04, 2010
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Memory stick error
Did you format the stick using the camera
if not then try that there seems to be a
problem when formatting with reader
Nov 19, 2007 | Sony Cyber-Shot DSC-F505 Digital Camera
It has a lens error. Everytime the camera is turned on it beeps and clicks constantly. It eventually shuts off after displaying "Lens error, restart camera." on the screen.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 23, 2009 | Canon PowerShot SD1100 IS Digital Camera
Sony cyber-shot Dsc-p32 error code
Try squeezing the camera very hard or slam the camera in your hand as hard as you can, this usually fixes it.
Oct 30, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
E:91:01 flashing and beeping few secounds after camera is turned on
e:91:01 is a flash error you might fix it by initializing the settings of the camera but there is no guaranty.
1.turn the unit on
2.press the menu button
3. select setup
4. inside setup and search for setup 1 (option with a toolbox icon with a number at the bottom.)
5. inside setup1, pls select initialize and reply with OK to evety prompt(using the center button)
6.if succesfull(you'll get clock settings)
7.set the date and time then try the camera again.
if this does not work.... call sony cust service 1800-222-7669
Jan 08, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Format Error C:13:01 on Sony DSC-W7
Please try with the new memory stick. Regards, Arpi
Mar 26, 2007 | Sony Cyber-Shot DSC-W7 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Sony Handycam CCD-TRV308 Camcorder Logo
542 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
