Question about Lexmark X3470 All-In-One InkJet Printer
I have a lexmark printer x3470 and i cant print any document?
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
Lexmark X3470 All-In-one Scanner keep on saying it Busy
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Oct 15, 2011 | Lexmark X3470 All-In-One InkJet Printer
Hello..i have a lexmark x3470,im able to scan to my pc but i cant print from my pc..what can i do?
There could be something that's blocking the printer communication like a firewall. This article will guide you on how to allow the Lexmark printer communications to have full access in your firewall: Cannot Print or Scan from the All-In-One Center with Any All-in-One Inkjet Product; Firewalls Prevent Unknown Processes from Functioning
Apr 27, 2011 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 can it print onto acetate?
there are overheads made specifically for printing from a inkjet printer. I have had good luck using "regular overheads" but just make sure you select "slow drying" media when you print or it will smear.
Nov 24, 2010 | Lexmark X3470 All-In-One InkJet Printer
Lexmar X3470 I print 1 document. Once it
That problem is related sometimes to old printer drivers. Please uninstall your printer from your PC and restart the PC then go to the Lexmark.com site and dowload the drivers for your X3470 those should be the new drivers and once installed they should not cause that problem.
Jan 13, 2010 | Lexmark X3470 All-In-One InkJet Printer
Is the Lexmark X3470 compatable with Windows Vista? I cant get it to scan onto my computer but it'll print fine.
Yes, according to the Lexmark website, your printer model is compatible with Windows Vista and even Windows 7. I would suggest that you uninstall the drivers for the printe/scanner and download the new drivers from their support website, then re-install the printer/scanner using those drivers.
You can find them here:
http://support.lexmark.com/index?locale=en&userlocale=EN_US&productCode=LEXMARK_X3470&page=product&segment=SUPPORT#1
I hope this solution helps you.
Aimeri
Dec 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 all in one printer
click the menu button and when you see colour, use the arrows to switch it to black copy.
Feb 04, 2009 | Lexmark X3470 All-In-One InkJet Printer
Odd behavior when printing
FrostPoptart -
An interesting issue. I think the driver may be causing the printer to 'misread' print jobs. I think installing the most current version of your printer's driver should resolve the issue; Rather than use the driver CD, however, use Lexmark's Driver Finder to locate your printer and download the most recent driver:
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&lxkprod=x3470&req=:::-1::
I hope this helps!
-thinstatic
Jun 12, 2008 | Lexmark X3470 All-In-One InkJet Printer
Printer lexmark all in one
ok..remove all s/w with control panel
go here to get fresh set of drivers through Lexmark icon
re install drivers
try again
Mar 27, 2008 | Lexmark X3470 All-In-One InkJet Printer
Paper jam lexmark x3470
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
Oct 16, 2007 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
