Question about Epson TM U375 Matrix Label Printer
Epson TM-U375 hey what is causing our 375's to not print on the left side? I have cleaned the head and ran the self test, but it doesn't print on the left side at all.
  • 5 more comments
  • Anonymous Jul 03, 2008
    TM-U375
  • mt0ne Aug 08, 2008
    I have 2 machines with this exact problem...
    Any ideas? It has nothing to do with the screw on the print head, that much I pretty sure about.
  • ppieklo Sep 04, 2008
    Same as Tigerweld's. During self-test, first 9 or 10 columns on left either do not print any characters or some characters randomly. Cleaning head improved greatly, close, but no cigar. Installed new print head which performed WORSE than the original. Cleaned contacts of ribbon cable into P. Head. No help. Looking to dig deeper into printer to examine ribbon cable connections, anything else on the inside.
    Must be a circuit bd. logic circuit component failure???
  • Troy Scott
    Troy Scott Oct 16, 2008
    Hey guys, I figured out what was causing it. Replace the ribbon! Seems this is the weak link of this model. I know it sounds crazy, but after we replaced the ribbons it worked for ALL of them and we repalced over 20 of them. We believe it somehow breaks the wires ( for lack a better word ) inside the ribbon and when it moves across to the right side it looses it's connection. If you want the dealer we use you will have to wait until I get back from vacation to look it up. They were reasonably cheap.
    The screw missing was by design. It was to save money on assembly. You only need the one. We use electrical contact cleaner to clean the heads with. It can be messy so be careful not to get the over spray on your clothes! Be sure and blow the printer out with air on a regular basis too.
    btw, you can test your printer by holding, I think the feed button while you cut it on. It will make a bunch of noise and quit. The light will be blinking. Release the button and press it again and it will run a print test, about 3' long. I think if you hold the feed button while cutting it on it will run a validation test. You will need to feed a slip to start the test. Again, I'm not at work and I don't have the printer in front of me so I may be backwards on the two buttons!
    One last btw, when you are taking it again to replace the ribbon be careful to note where the screws go. There are different sizes!
    I hope this helps you guys! My trial and error paid off I hope!
  • Troy Scott
    btw, when I say 'ribbon' I mean the ribbon to the head, not the ink ribbon.
  • joshcall Jan 15, 2009
    OK, def not the ribbon cartridge, tried 2 brand new ones... no luck, still only prints right half of receipt!!
    Anyone got a part number for the data cable going to the print head??
    I think that's the most likely part that's failed.
    Anyone else with advice on these TMU375's printing half a receipts???!??
    Thanks!!!!!
  • Anonymous Apr 06, 2009
    even after changing the ribbon on the printer, the print is very light on the receipts, espically on the dollar amount on the right side of the ticket. It prints well on the teller tape.
The Print head ribbon cable is 99% of the problems on printing! Don't worry about any cable coming from the unit to the machine itself. Now there is a Platen bar that the ink ribbon presses on to print. So if is light on one side or both you can adjust that! Go from the back side or the unit, you should see a black box thing. On each side is adjustments, stick a flat head, small, screwdriver in there and turn it. Be careful!!! You do not want to turn to hard it is plastic and will strip!!! That will adjust your platen bar.
If any more problems let me know! I work on these everyday!! Welch Systems Inc. Peoria, IL
Posted on Mar 08, 2010
I have a part number of 2014551 for the printhead cable. I use compassmicro.com for all my epson parts
Posted on May 18, 2010
Does anyone have the part number for the printhead cable, instructions for replacement, and a vendor to buy from?
Posted on Sep 22, 2009
The problem is the printhead cable. I've had this problem numerous times and it fixes it every time.
Posted on Oct 15, 2008
Found manual but not really any help, in ref to head assembly. I guess I will figure it out on my own, here is the link if you need it.
http://content.epson.de/fileadmin/content/files/RSD/AnwenderhandPDFs/DE/TM-U375_user_e.pdf
Posted on Jul 03, 2008
Look at the head assembly, notice it has only one screw, it appears the one on the left is missing, hmmm just like the side that doesn't print. I have been trying to find a repair manual for this, so I can fingure out how to adjust the head, once I add the missing screw if one goes there. All my printers are like that, so I dont know if one really goes there, haven't tried.
How to repair no print of pos printer epson tm t88iv?
did you try the basics cleaning heads , running test setup for the dot matrix printout out , changing ink sometimes ne packages sold are garbage.
Sep 05, 2014 | Epson Tm-t88iv Black Thermal Receipt...
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
Left 1/3 of receipt not printing
Run the cleaning programme on your printer, you will find it in the menu for maintainance.
Nov 14, 2013 | Epson TM-U375 Printer
I received a cleaning failed message on my epson TM-u325d
For some reason, our clients bought the Epson TM-U325D, and now we are charged with the duty of fixing these things. So, I, naturally ran the self-test upon first starting the printer (hold down the feed button while powering it on) and it went through both parts and I received a "Completed" message. After a second, it printed out a message that said "This is validtion sensor self-cleaning start message. Wait for a while.". It then began opening and closing the clamp for about five or six iterations of this. Then it prints :Cleaning failed. Please call a service person." Sound like your message or error? Well, in this particular instance, this is how I solved it:
First, I removed the printhead, and cleaned out the built up, dried ink along the pins just behaing the print surface. I ran 99% denatured alcohol through the printhead (careful to not get it on the PCBs, but let it flow out the front) until the alcohol came out clear. I then disassembled the print mechanism and cleaned the two rods, the printhead carriage with alcohol. I then took some simple lubricant like MArvel Mystery Oil and lubricated the felt bushings within the printhead carriage and the two guide rods. I then made sure no pieces of debris like paper dust or pieces of paper were anywhere else. I put everything back together, and the error no longer occurred.
Hope that helps. I've fooled with several validators, and 95% of the time, it seems to be that they are just dirty if they haven't been abused or run to *****. It can be time consuming, but a lot of things can be fixed with a thorough cleaning.
Mar 02, 2012 | Epson TM U325D Matrix Printer
Tm-u295 firmware problem?
I can solve that problem but i need some help in the firmware of TM U220B. I just need the .bin files to downgrade to version 1.02
Feb 18, 2009 | Epson TM-U295 Matrix Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
May 09, 2008 | Epson TM-U220 Matrix Printer
Receipts
theres no platen gap lever/adjuster on those type of printer which are normally found on dot-matrix printers
Feb 12, 2008 | Epson TM-U220 Matrix Printer
Epson TM U375 Matrix Label Printer Logo
1,999 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
