Question about Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher started smelling funny like electrical smoke. I opened up the top by the digital read out and noticed one of the wires was charred and had been smoking. worth it to call repairman? or buy a new one.
  • 311 Answers
I would call a repairman or just cut out the bad spot in the wire and use a **** connector and splice in some new wire. Maybe a new connector because it may have been caused by a loose connection drawing heat due to arching. I doubt its a major issue however it may be worth it to call a repairman just in case because it could potentially be a fire hazard. It may even be a recall on the dishwasher I would check your model number through MFG to see if there were any recalls.
Hope this helps _MJ_
Posted on Feb 07, 2010
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
Sudden strong smell of smoke in cab of car
as you did not bother with a make , model year data we cannot help
it could be an alternator fault , shorted wires or starter motor stuck in the ring gear
get an accredited auto electrician to check for the fault
Apr 25, 2017 | 1997 Oldsmobile Cutlass Supreme
I have a LTD25 classic and my buddy hooked a 12v power supply up to it and got the polarity wrong and it started to smoke. It will still come on and light up but will not transmit, I am suspecting this...
try usung a soldering iron. they are fairly cheap. once you remove the peice thats charred take it to your local radioshack and ask them to match it up...
Aug 25, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Wow great site! Problem with my 600 series penguin Unit started acting strangely last weekend, smelled something electrical when I first turned it on. but then cooled fine. This weekend DW took it out for...
Hello my name is Heath it will be my pleasure to assist you. What you are looking at is the start capacitor for the motor a $7 part at any HVAC supplier. If it is leaking it is definitely bad and needs to be replaced. This gives the compressor a boost on start up and drops out of the circuit after the compressor is running.
Jun 13, 2010 | Dometic Rooftop RV Air Conditioner
My oven keeps switching off, and it doesnt come back on until I turn the temarature up. Its almost as if it is over heating
your power cables might be loose on the electrical board, turn off breaker to oven, open it up and verify the wires from the wall are tightly connected to ther posts on the electrical board. If you smell a funny smoke or weir smoke it is electrical problem and shut it off immediately at the breaker box...Cal a repair guy if you don't have to call the fire department.
Oct 13, 2009 | Tecnik TKC8525 Double Oven
Kitchenaid (KUDM01TJWH0)
wires where thy bend at bottom of door and heating element....water in motor
Aug 14, 2009 | KitchenAid 24 in. KUDM01TJ - Multiple...
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Kenmore 24 in. 15079 Built-in Dishwasher Logo
373 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
