Question about Maytag Atlantis MAV6000 Top Load Washer
Washer just stopped working and smells like something just burned
  • 530 Answers
Take the belt off and let me know if you still smell burning
next with the belt off turn each pulley under the washer there are 3
the big one in the middle...in one direction makes the unit agetate in the other releases the break and the basket turns.. does this happen?
next the pulley to the right is your pump how is that does it sound strange when you turn it?
next spin your motor pulley does it spin freely?
let me know what you find
Posted on Feb 07, 2010
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
White smoke coming from the machine, it was in the middle of the extended cycle. stopped machine and unplugged. Smells as though something burned.
Usually the first repair a Maytag washer needs is to replace the belts. They can wear out and smell.
The belts are located on the very bottom of the machine. They are not covered. If you pull out the washer about 2 feet and lean it back against the wall you will see the belts on the bottom.
If they have shiny parts, or one of them was sticking. You will be able to see if it is burned.
I've made a diagram to help.
The "main drive pully" is the belt that is most likely to be burned. It is also possible for a clothing item such as a baby's sock, to get caught in the pump. That being the case, the pump belt can burn.
If you replace the belts, which you should do if the machine is 10 years old. You must replace them with Maytag belts. This is important, because they are designed to allow some slippage. If you replaced them with belts of the correct size but not the right type, the machine will not work properly.
Of course, the machine can have electrical problems, but it is rare. Let me know what you find and I can advise you further. Happy New Year, Mark
Jan 02, 2011 | Maytag MAV3855A Top Load Washer
My washingmachine stopped working and gave off burning smell. How can I determine if its the motor thats burned out or something else?
Had one similar to this about three years ago. That burning smell would be the belt that runs the washer. Relatively easy to repair. You'll need make and model number to get the right replacement belt. Once you have it, get up under it, remove the old belt and put the new one on the same way. The belt will go around the pulley on the bottom of the washer drum, the motor and the tensioner. This should solve your problem. If you need more help, please let me know.
Oct 27, 2009 | Frigidaire FEX831CS Top Load Stacked...
Smells like motor is burning. during first wash cycle, washer stopped and there was an electrical burning smell??
YOUR WHIRLPOOL WASHER COULD HAVE A MOTOR PROBLEM, IT IS POSSIBLE THAT SOMETHING HAS GOT CAUGHT IN THE MOTORS WINDINGS AND SHORTED IT OUT. IT YOU CAN STILL HEAR THE MOTOR RUNNING BUT THERE IS NO AGITATION IT COULD BE THAT YOUR DIRECT DRIVE COUPLER NEEDS TO BE REPLACED, PART NUMBER IS 285753. THIS IS A COMMON PROBLEM, ESPECIALLY WHEN THE WASHER IS OVERLOADED AND CAN CAUSE A BURNING SMELL SINCE THIS PART IS RUBBER AND PLASTIC. IF YOUR WASHER IS MAKING ANY SORT OF BANGING NOISE THIS COULD BE THE PROBLEM. YOU CAN CHECK THIS BUT IT DOES INVOLVE REMOVING THE PUMP AND MOTOR. ANOTHER POSSIBLE PROBLEM IS THAT THERE IS SIMPLY A BURNED CONNECTION ON YOUR UNITS ELECTRICAL SYSTEM AND IF IT CANNOT BE REPAIRED IT WILL HAVE TO BE REPLACED.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Maytag pav1000aww stopped working
Sounds Like Your Belt Broke And Seized The Motor.
Jan 12, 2009 | Washing Machines
Washer smells like something is burning and it won't work at all
i would check the motor, and also the coupler that mates the motor to the tranny
Nov 26, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washer just stopped
I would check the drainpump ans see if there is something jammed inside like a coin or screw,nail etc before doing anything else .Unplug the machine first though . A burning smell will occur with a load of water trying to spin .
Nov 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag Atlantis MAV6000 Top Load Washer Logo
219 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
