Need to know about a goodman gaspack the lightflash 4 time what dose it mean
  • 407 Answers
I'm assuming that your talking about a Goodman gas furnace? If so, then four flashes on the board means a limit has been tripped. Two things you can do are, make sure that the return air is not blocked in any way and make sure your filters are clean, if not that, then there is a small hose that goes into a blower (usually up top) that has a small wheel that spins, and also goes to a limit switch that has two wires hooked to it. Try taking that hose off on the blower housing and stick a small wire into it to make sure it is not clogged (you won't be able to tell until you put it back together and turn it on). Also take the hose and **** and blow into it while it is still hooked to the limit switch. If you hear it clicking back and forth, then that switch is good. The other limit is screwed into the heat exchanger compartment and also has two wires that run to it. You can shut power off to the unit and check continuity between the terminals to make sure that it has a connection. Sometimes you can take it out and clean it a bit, then put it back in and it works, but no telling how long. I hope this helps some.
Posted on Feb 07, 2010
My Goodman GMP 125-4 furnace has 4 blinking lights and we currently are unable to get it to come on. What might be wrong?
if this is an error code and you mean that the light blinks 4 times then it is the limit circuit. This could mean either the high limit or a roll out switch is open. the limit switch is right in the center of the furnace above the burner and roll out switches are probably somewhere around the opening of the burner. Follow the wires from the limit to find a roll out switch cause they are in line with each other and the rool out switch could have a button to reset it. However if the roll out is not tripped then you could need to change the limit. Only way to know is to check for continuity.
Dec 04, 2010 | Goodman GDS80904BNA Open Flame Heater
Gas dose not come on
The blinking light is giving you a trouble code for the unit. It should have a label or something inside the unit or in your owners manual to let you know what the code means. Count the number of blinks. It should repeat over and over.
Jun 06, 2010 | Goodman GMS90703BXA Heater
Goodman gaspack problem
Hi check the flame sencer is clean
Mar 23, 2010 | Heating & Cooling
I have a goodman gmp100-4 gas furnace and the gas comes on but shuts off in around 30 seconds, then tries again and the same thing... can i get some help please?
On the last gas venturi tube there should be a flame sensor located in the flame to prove it exsists, if its coroded the spark can,t jump back thru the moisture molecues in the gas to prove it has a flame to tell the circuit board to keep the gas comming. Just reomve the flame snsor and sand itand replace itback. T. Y. V. M.!
Dec 01, 2009 | Goodman GMS90703BXA Heater
My goodman gaspack has had two incidents of cracked heat exchangerS within 18 months apart. Could something be cAUSING THIS TO HAPPEN?
Things to watch for when your heat exchanger is cracking....
1.Always kee the filter clean
2.Make sure the return air vents are clean and clear of obstructions
3.Your furnace could be Oversized for your house thereby running too hot.
4.The furnace can be "Overfired" basically burniing more gas and running hotter than it's supposed to be
5.It's always best to have your furnace taking fresh air for combustion from outside...basically you should have 2 pipes on your furnace ..one for Air Intake and the other for Exhaust
6.Sometimes some furnaces have a Bad Design and are prone to failure...Some Goodman have "Rings" basically large rivets that pop...this was a bad design however all the suggestions above should help but may not eliminate your problem
Oct 31, 2009 | Ruud UPMC036 Air Conditioner
I have a new Goodman GasPack heating and A/c unit. I turned the a/c on for the first time this year and I'm having problems with the theromastat. When it is set at any set point say 77 the a/c comes on...
If the space temp is (example) 72 degrees and you set at 80 degrees the unit should not come on. The A/C comes on when the space temp gets 2 degrees above setpoint temp. What type of tstat was installed digital or old syle mechanical. I'm leaning more towards a short in tstat wiring
Jun 04, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman pgb 0300751 gas package unit. The unit started running both the combustion and circulating fans. Technicians have put two new honeywell boards in it. the fans are still running. all circuits and...
then you need toi have them check the fan high limit that is mounted in the blower compartment. if it's closed then the blower fan and the conmbustion air fan will run together.
Feb 03, 2009 | Heating & Cooling
Goodman Draft Induction Fan Keeps Cycling On and Off
can you write down where the low voltage t stat wire go and disconnect the white wire at the unit to eliminate a short between the white wire and the red wire usually the colors are as follows red is 24volt , green is fan , white is heat, yellow is cooling I want to narrow down the red is not shorting to the white briefly let me know if this is possible if not we can try other checks
Jan 06, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
