Question about Pyle Pl1156rd Led Brake Lights Light Bulbs Pl1156rd
I have a 1996 buick lesabre i need t know how to change the rear side marker bulb
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
I have a 2002. If it is the same you have to go into the trunk behind the inside fabric side cover and loosen the bolts that hold the light assembly on. Then the bulb holder should twist and come out to get to the bulb.
Posted on May 25, 2010
Changing backup bulbs on 2005 buick rendevous
TAIL LAMP ASSEMBLY AND /OR BACKUP, SIDEMARKER, STOP, TURN SIGNAL BULB REPLACEMENT
REMOVAL PROCEDURE
1. Open the liftgate.
2. Remove the screws from the tail amp.
3. Slide the tail lamp rearward in order to disengage it from the retainers on the rear body panel.
4. Disconnect the electrical connector from the tail lamp wiring harness.
5. Remove the tail lamp and side marker lamp sockets from the tail lamp, depressing the locking tab and turning counterclockwise.
6. Remove the bulbs from the tail lamp and the side marker lamp sockets, if replacing the bulbs.
INSTALLATION PROCEDURE
1. Install the bulbs to the tail lamp and side marker lamp sockets, if removed.
2. Install the tail lamp and side marker lamp sockets to the tail lamp, turning clockwise until the locking tab is fully seated.
3. Connect the tail lamp electrical connector to the wiring harness.
4. Position the tail lamp retainer slots to the tabs on the rear body panel.
5. Install the tail lamp to the rear body panel, pressing into place until fully seated.
6. Install the tail lamp screws to the Taillamp.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp screws to 2 N.m (18 lb in).
7. Close the liftgate.
Apr 16, 2017 | Buick Cars & Trucks
Which bulb is the rear blinker on a 2001 LeSabre?
Its the large bulb.
The small bulb is the side marker bulb. The larger bulb (3057 or 3157) is the combo tail-stop-turn signal.
There is also a single filament bulb for the backup light.
Jul 27, 2012 | 2001 Buick LeSabre
My rear marker/ running lights are out and i need to know how to get to them
Signal and Marker Lights Removal & Installation To Remove:
  1. Remove or disconnect the following:
    • Screw from the side marker lamp.
    • Side marker lamp from the front and/or rear bumper fascia.
    • Bulb/socket from the side marker lamp.
    • Bulb from the socket.
To Install:
  1. Install or connect the following:
    • Bulb to the socket.
    • Bulb/socket to the side marker lamp.
    • Side marker lamp to the front and/or rear bumper fascia.
    • Screw to the side marker lamp. Tighten to 2 N.m (18 lb in ).
Jan 08, 2011 | 2002 Pontiac Sunfire
Need help changing out the low beam on drivers side of 2006 buick rainier
Bulb Replacement
To Remove:
CAUTION
Halogen bulbs contain pressurized gas.
Mishandling a bulb may result in the bulb shattering into flying glass
fragments.
CAUTION
Make sure to wear eye protection when
handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb,
only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into
contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb
properly.
CAUTION
Do not allow children to handle halogen
bulbs.
  1. Turn the lamp switch to the off position.
  2. Make sure the bulb is cool before changing.
  3. Remove the headlamp assembly from the headlamp panel.
  4. Remove the rear access cover from the headlamp assembly.
  5. Disconnect the headlamp connector.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket
    counterclockwise.
To Install:
  1. Connect the headlamp connector.
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket
    clockwise.
  3. Install the rear access cover onto the headlamp assembly.
  4. Install the headlamp assembly into the headlamp panel.
Headlamp Assembly
Chevrolet
To Remove:
Headlamp Assembly (Chevrolet)
  1. Remove the grille from the front of the vehicle.
  2. Release the headlamp assembly retaining tabs.
  3. If equipped, disconnect the headlamp leveling motor connector.
  4. Disconnect the headlamp connector.
  5. Remove the park/turn and side marker bulb sockets from the headlamp
    assembly.
  6. Remove the headlamp assembly from the headlamp panel.
To Install:
  1. Place the headlamp assembly into the headlamp panel.
  2. Install the park/turn and side marker bulb sockets into the headlamp
    assembly.
  3. Connect the headlamp connector.
  4. If equipped, connect the headlamp leveling motor connector.
  5. Lock the headlamp assembly retaining tabs.
  6. Install the grille onto the front of the vehicle.
GMC, Oldsmobile, Buick, Isuzu, and Saab
To Remove:
Headlamp Assembly (GMC, Saab, Oldsmobile, and Buick)
  1. Release the headlamp assembly retaining tabs.
  2. Disconnect the headlamp connector.
  3. Remove the park/turn bulb socket from the headlamp assembly.
  4. For GMC, Saab, Oldsmobile, and Isuzu vehicles, remove the side marker bulb
  5. Remove the headlamp assembly from the headlamp panel.
To Install:
  2. For GMC, Saab, Oldsmobile, and Isuzu vehicles, install the side marker bulb
    socket into the headlamp assembly.
  3. Install the park/turn bulb socket into the headlamp assembly.
  4. Connect the headlamp connector.
Oct 28, 2010 | 2006 Buick Rainier
How do I change the rear, passenger side turn signal bulb on a 2005 Buick Lesabre?
open the trunk and pull carpet away from the lens your working on,you will see four black thumb nuts,remove them and pull lens assembly out to get to bulbs
Jan 29, 2010 | 1994 Buick LeSabre
Replacing brake light bulb
OPen the trunk and remove the access cover. The bulbs just twist out from the rear.
Nov 18, 2009 | 1998 Buick LeSabre
Turn Signal Fuse or switch replacement? '93 buick lesabre?
Yes all the wiring needs to be complete. Then all the bulbs must be inserted into sockets. left side marker right side front turn back turn reverse lights brake light everything. Then make sure they all work. The problem could even be a bulb thats on the fritz ready to blow but still on and dim little light. if that's all fine then it's probably your flasher. There are 2 flashers one for turn and one for hazards but I think they are the same but still separate. located under dash on either side of the steering wheel. The flasher closest to the door is up in there pretty far it's size is about like a 2 liter cap and it's silver. good luck
Sep 17, 2009 | 1993 Buick LeSabre
Replace taillight bulb - how remove to access it?
wing nuts on innide of trunk hold lens assembly in remove all fastners and slide out assembly to access light sockets on rear of lens.
May 07, 2009 | 1996 Buick LeSabre
Change bulb right rear blinker 2000 buick lesabre
you have to open the trunk take the carpet off right next to the very back of car undo the 3-4 plastic wing nuts take light off of car change bulb ......reinstall reverse of taking off
Mar 22, 2009 | 2000 Buick LeSabre
Need to know how to change brake light on 1997 buick lesabra lim
There should be wing nuts on the backside in the rear body panel. You need to take the trim of the rt or left side you also may have to take the sill plate off for access.
Jan 24, 2009 | 1997 Buick LeSabre
Pyle Pl1156rd Led Brake Lights Light Bulbs Pl1156rd Logo
65 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
