Question about Roper Refrigerators
Icemaker fingers frezzes up wan't turn - Roper Refrigerators
  • 311 Answers
If there are frozen cubes in your ice maker then your heater or thermostat on the unit is bad. It will need to be replaced.
Posted on Feb 07, 2010
Amana model tg21vl stops making ice
pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
Feb 24, 2013 | Refrigerators
Summerhouse in wintertime, without indoor warming: can I use glycol to avoid frezzing?
I would not reccomend it,if it is something you dont want on your dishes and cookware its not a good idead to add to dishwasher. You could turn off water supply under sink start washer to relieve all pressure from supply line and remove drain hose from pump tolet out all water that it contained at all times. I would do this for dishwasher,washing machine and if equipped the water valve on the refrigerator icemaker.
Aug 17, 2011 | Dishwashers
Icemaker leaking water and frezzing ice into one large block
take the freezer panel off. unclog the hole where the water collects. its clogged
Feb 13, 2010 | Hotpoint HSS25GFP Side by Side...
GE refridge icemaker won't work
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
Makes ice but is very slow to dispense and makes a load bumping noise
Turn off the water to the icemaker. Locate the plug from the icemaker to the freezer & disconnect it. There is usually 2 screws under the icemaker that mounts it to the freezer, remove them. Some may have a screw or 2 in the top also. these are only short sheetmetal screws. You should then be able to extract the icemaker, a short hose attatched to the icemaker will come out of the back of the freezer. When complete the freezer/frig will work fine. Thaw out the icemaker, drain the water out, inspect the rotating finger grate area for any objects. Shaking it upside down may help. Reinstall & test, if it doesn't work it is bad. You can take it to an appliance repair store to replace.
Nov 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
How the icemaker not working properly. It's not been products the ice
check if the water tube is connected and turn on ,then if thats not the problem turn of your frige of for 2days ,then put it on and will work,thats usally the main problem due to water frezzing all around the is maker and freezing it all and after that make sure to not over fill the ice but dump it ,if my info was of any help to you please leave a comment thankyou.
Sep 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our Uline icemaker is not making ice anymore after having to manually defrost the unit. Water doesnt even go into the unit, and now it isnt cooling.
You might of turn it off in mid cycle. You can check the icemaker ejector blade (fingers that push ice out) If thats not at 12 oclock you will have to manually advance it so it will be at 12 oclock position. Remove cover off icemaker. Just pull it off you might need to pry it on the corners to help it along. Becareful that you dont break the cover. When you have it removed you will see 2 gears. the smaller one should have a 5/16 head on it. Turn that counterclockwise to advance the ejectorblade back to 12 oclock. Once you have it in that position turn your unit back on and see what happens.
Aug 10, 2009 | U-Line Icemaker
Ice maker fails to make ice tried several times to turn switch on and off water flows to the cold water dispenser worked OK for the past several months what to do??
I hate to say this but from experience on LG icemakers if the fingers aren't turning or the if you have the flextray model the only fix is a new icemaker. Make sure the fill tube to the icemaker is not frozen also.
Oct 23, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
47 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
