Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
I am trying to clean and service the laser 30 and cant figure out how to get the top off of the unit.
    Novelist:
  • 126 Answers
Dave,
The front panel comes off by removing the screws at the bottom outside corner of the panel. Slide the panel down about an inch and it will come off. The top panel has two screws in the back that hold it in. Be very careful with the wiring connectors when you put them back. They only go one way.
Tom
Posted on Feb 08, 2010
I would like to clean the laser on this machine but cannot see how to remove the case. The open vents on the top allow alot of dust to accumulate inside. There must be a way or how can it be cleaned? The...
First off, cleaning will not fix the problem. Replacement is the only solution. Go to TigerDirect or Amazon for a new DVD read/write unit. $30 to $40 and your back in business.
Feb 15, 2018 | NAD Viso Two DVD Player / Receiver
Ink jet print head
Unseating and reseating the cartridge
Turn the unit on and open the lid or top cover.
Remove the cartridges.
Re-insert the cartridges.
Close the unit’s lid or top cover.
Cycle the power to the device by turning the printer off for a few seconds.
Turn the printer back on.
Print a test page. If this does not solve the problem, proceed to the next section.
Wiping the cartridge contacts
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom (see Figure 1). The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
Figure 1: Cleaning the cartridge contacts
The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom (see Figure 2).
Figure 2: Cleaning contacts inside the printer
Re-insert the cartridges and close the printer’s top cover.
Print a test page. If the problem persists, perform a hard reset as described in the next section.
Performing a hard reset on the unit
When the printing unit detects an issue with the cartridge, a software flag is set inside the device. This flag may not reset until performing a hard reset on the device.
HP Deskjet and Photosmart printers
Verify that the unit is switched on.
Open printer and remove both cartridges.
Unplug the power cord from the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Open the top cover and reinsert both cartridges.
Turn the unit on.
Print a test page. If the problem persists, the cartridge should be replaced.
HP Officejet and PSC all-in-one
Remove the power cable from the back of the machine.
Wait 30 seconds.
Press and hold the POWER button on the front panel.
Reinsert the power cable in the backside of the unit.
Jul 25, 2008 | HP PSC 750 All-In-One InkJet Printer
I have a problem with the CD/DVD Drive like for some reason i'll put a cd in the drive and it'll spin but it can't read it and i used to make cds before and can't make cds anymore .. i made...
Try cleaning the lens that sits on top of the laser - use something like
http://www.amazon.co.uk/Hama-DVD-Laser-Cleaning-Disc/dp/B00005UPDF
If that doesn't work then the laser has died, and the entire unit with it - it happens. Time for a new one, it's just $30 at every pc shop.
Aug 29, 2011 | HP Pavilion Slimline S3020N PC Desktop
Our wii is not reading disc, we get a message that it is unable to read the disc. any suggestions
hello you could try and clean the laser by hand take the top off the wii you'll see the laser unit take the top off the laser unit you'll see the laser eye get cotton wool pud and nail varnish remover give it a clean should do the trick good luck
shaun
Aug 03, 2009 | Nintendo Wii Console
Kenmore 4563291 top loading washer quit in rinse cycle power to machine is good but total unit is dead - Cant figure how to get to timer circuits etc. Cant find parts manual or circuit diagram
unplug for 30 seconds then plug back in and advance timer around to start again. if still nothing take off the top back panel there should be a fuse
Apr 15, 2009 | Washing Machines
Error 22 whats that?
The EE22 message means the stove quit with an EE2 three time in a row. In order to clear the EE22 you must unplug the unit for 20 minutes. Then you can try again. It sounds like you have the fuel problem figured out?
Tom Hawkins
hawkins111@gci.net
Apr 01, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 30 EE12
Robert,
If your screen is clean and the circulating fan motor works you will have to remove the front cover. Take the two screws off the bottom and move the front down and off. The top will need to be removed as well. There are two screws in the back. Move the top cover forward and lift it up. You may see the plastic cover that is meant to cover the circuit board is laying down in front of the overheat switch. If so just lay it back over the circuit board.
Keep us posted if this is the case. I have seen two new heaters this way in the last 6 months.
Tom Hawkins
hawkins111@gci.net
Mar 17, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
ERROR 22
You Need to Try One Of The Following :
Remove and re-install Imaging Unit (make sure that Imaging Unit
is locked in place). Turn the printer off, then on.
Replace Imaging Unit (make sure that Imaging Unit is locked in
If problem persists for Error 30, clean the sensor.
If problem persists, check www2.tek.com/merlin/tko and/or
contact Service.
Dec 05, 2008 | Tektronix Phaser 740P Laser Printer
I just doesn't load/read CD's.
I had the same problems with my four year Denon DVD-3910 and the only solution to it was to replace the laser unit with a new one.
There are some repair service on EBay that offer new laser units for only about 50 € and are also willing to change the laser unit for an extra charge of just 30 €.
After this replacement your Denon DVD-3910 will work fine again.
Sep 10, 2008 | Denon DVD-3910 DVD Player
DVD playback
Samsung dvd players are known for bad spin motors. You may try to clean the laser and see if that changes the disposition of the problem. If there is no change and with the top of the unit off,if you see the pin point of laser on top of the disc, and the disc moves or shivers, the chances are it is a bad spin motor. In most cases, it is not cost effective to replace the motor. If an auxillary line in jackis available , buy a $30 dvd to replace it rather than taking it to a service facility that will charge you the same amount to evaluate it. Scrivitron
Jun 15, 2007 | Samsung DVD-VR330 VCR and DVD Recorder
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
64 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
