Question about Brother HL 1240 Printer
Brother Printer HL 1240
Printer is not printing. all lights keep blinking. ive replaced the drum, the toner pressed the reset button several times, and turned off the power, but the lights just keep blinking.
  • 3 more comments
  • Tise Mar 09, 2008
    Since power outage from storm a week ago, printer lights just keep blinking when power is turned on. The drum light alternately blinks in between the all lights blinking. I pulled the toner cartridge out and set it back in, but ** change.
  • Anonymous Jun 24, 2008
    changed drum & cartridge all lights flashing on & off
  • loulights Aug 16, 2008
    yes same problem, seems while I was away power in home must have been out, now all lights flashing, first drum light then all lights. any solution other than tossing it out? sad part is i had just replaced the drum and tonor.
    OK figured out the sequence to resolve this error:
    power off unit
    unplug power cable for 1 minute
    reset the power cable
    open front door
    press and hold the reset button under the lights
    turn the power on
    printer should then be reset
  • Anonymous Dec 29, 2008
    I have a Brother HL-1240 that won't print. System is asking to reset printer. Over the weekend we had a power outage and created a few printers to do the same.
    Can anybody help me
power off unit
open front door
turn the power on
Posted on Aug 16, 2008
Same experience -- HELP!
Posted on Mar 06, 2008
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
Just put a new toner in; turned printer off and back on; still the same problem; lights are blinking and won't print
Sound like your drum is gone. I just had to put mine to it's grave. Drum cost more then the printer is worth!
Jan 27, 2011 | Brother HL 1240 Printer
Brother 1240 drum and ready lights stay on, will not print. The drum light is yellow, and the ready light is green. They are not blinking.
This printer has an on/off switch (on the left side near the bottom), and only one button, situated on the left edge of the front panel, under a column of four colored LEDs.
First, open the front of the printer, as if you were going to replace the toner or the drum cartridge. Then, while the front of the printer is open, press and hold the button (which is now just a piece of plastic film) until the lights all turn off, and then turn on again, one at a time. This took me a few tries. I held down the button/film until that top yellow (drum) light turned off, and once that happened, the other lights all turned on, one at a time, from top to bottom. Then I closed the front cover and the printer works again.
I had tried turning the printer off, and then turning it back on while holding down the button. This did not resolve the problem. I also replaced the drum (twice) and the toner cartridge. I would recommend trying the above procedure, which apparently resets some type of counter relating to the drum, before spending (wasting?) hundreds of dollars on replacement cartridges.
Aside from the above problem, which has now apparently been resolved, the Brother laser printers in this series have been quite reliable and easy to use. I own three of them, and they all get fairly heavy use.
Dec 29, 2009 | Brother HL 1240 Printer
I've recently installed a new Brother toner, but the drum light is flashing and the Brother hl 5140 printer won't print
DRUM UNIT "spent"
It can be reset if the printing quality is good
To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Oct 09, 2009 | Brother HL 5140 Laser Printer
Brother HL 1240 - page runs through printer, nothing prints
Did you pull the plastic tape on the new cartridge?
Jun 29, 2009 | Brother HL 1240 Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother printer Hl 2070. Toner light is on , changed the toner , still yellow light is on and I can't print
From Brother.com: Description:
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Caution
Apr 06, 2008 | Office Equipment & Supplies
BROTHER HL-2040
I think the previous post applies to resetting the drum light after replacing the drum.
You need to reset the toner end-of-life condition.
  1. Open the Front cover
  2. Press and hold the GO button
  3. Power ON the printer while continuing to hold the GO button
  4. All 4 LED's will light up and then 3. Once the 3 LED's are lit, release the GO button
  5. Press the GO button 2 times. This will cause the
    LED's to light solid
  6. With the LED's lit solid, press the GO button 5 times
  7. At this point the Paper light should be blinking. Toner end-of-life has been reset
  8. Close the front cover.
Dec 10, 2007 | Brother HL-2070N Laser Printer
Brother HL 1240 Printer Logo
969 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
