Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I'm seeing a green light blinking in the freezer area, and the ice maker is making ice very slowy.
  • 572 Answers
Might need a water filter. check the light indicator
Posted on Feb 07, 2010
Why is there a flashing green light on the icemaker?
First, pull out the ice bin and eyeball the ice maker device behind it. See if the switch is turned on and the green light is lit. If it's blinking, that indicates "ice stuck in tray" and you'll have to take it out and thaw the whole contraption out. It's not that hard: unplug the giant molex connector on the right side and use a small hex wrench to unscrew the obvious screw holding it to the left side of the freezer wall. Then you can firmly pull the device up and out until it pops free from the notches where it sits in the back.
If there's ice stuck in the device, or if it's just not filling properly, let it sit out for a few hours until it warms up. Depending on the humidity conditions in your freezer, something could have frosted over.Check the swing arm on the bottom of the device. Despite the appearance as a bit of useless plastic, it has a magnet attached to an arm inside the main ice maker housing which allows the maker to tell if the arm is extended or pushed part ways in. Ice being make and pushed into the bucket depresses the swing arm when it falls and the arm returns to the extended position via a small spring mounted between it and the unit unless the ice maker is full. This spring has a habit of popping out of a tiny hole and not providing the force needed for the arm to return to "make more ice" position. Check that it pushes back at you if you depress it.
Hopefully one of these items you've checked wasn't working because they're all easy fixes. Reassemble and add it back to the freezer, making sure that the water dispenser in the back of the freezer leads INTO the ice maker, not BELOW it. This would cause a mess. Make sure the thing is plugged in again, and the green light is back on.
If you're impatient about waiting for another ice cycle to start, depress the swing arm three times in a row. This should tell the ice maker to immediately dispense water and start a new cycle.
Jul 02, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
Fim120 flashing green light
is there any pause in the blinking light if so count the blinks and the pause and the seconds blinks this will tell you the error code
Dec 11, 2013 | Franklin Chef 120lb. Ice Maker FIM120
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
Jul 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Top freezer ice maker not putting out ice
We shut down the freezer for 12 hours and the ice melted in the pipe. Thanks
Jun 21, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Apr 12, 2008 | Refrigerators
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
