Question about Exercise & Fitness
How do i replace the motor drive belt - Exercise & Fitness
    President:
  • 832 Answers
Open motor shroud to expose motor area then go to the other end of your treadmill and loosen the running belt this done mostly with a allen wrench count how many turns counter-clockwise it take to fully loosen the belt. then loosen the motor, depending if its mount up against the or the bottom of frame they will have bolts to loosen if its on floor of the frame mark the bracket so when you put back the new drive belt you should in the ball park to adjust the tension. depending on the model some front rollers are fixed and you only need to loosen the two two bolts lift the roller up replace the belt work backwards on the steps you performed.
Posted on Mar 01, 2010
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
How to t6.3 drive belt adjustment
Afix the drive belt onto the drive motor flywheel, then force the drive belt onto the roller pulley by turning the roller
Dec 29, 2013 | Nordic Track NordicTrack T6.3 Treadmill
Bowflex TC5000 L5 Belt will not move antmore.
Dear Sir:
Hello , I hope everything is fine with your family.
Thank you by your request, and I will help you inmediately.
You have a Mechanical problem, please do the following:
Please do this with carefully!
The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset.
Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it. A drive belt is usually $29.99 or less while many parts you can damage by over tightening can be more than $300.
Additionally, too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure. It is better to having the belt a little too tight rather than too loose due to the possibility of injury if the belt slips.
Motor Belt Adjustment- Icon Units
DO NOT REMOVE ANY OF THE MOUNTING BOLTS TO THE MOTOR. SOME MODELS WILL REQUIRE 2 9/16" WRENCHES AND MAY REQUIRE TWO PEOPLE TO ACCOMPLISH THE REPAIRS
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stallthe belt to make it slip.
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts
. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5.
Step 4-
If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5.
Step 5-
If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The entire front roller assembly repaired or replaced (see the help topic on replacing a pulley) and the drive belt must be replaced. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position.
Thank you in advance, sincerely. God bless you.
If you need further help, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 27, 2011 | Bowflex TC1000 Treadclimber
Belt is slipping and I need to know what maintenance I should be doing on this model as I have no manual for it.
Hello, There is no maintenace required. Some people like to oil the walk belt, The manual say to do this annually. To do this you loosen the walk belt and applty some synthetic oil to the walk board under the walk belt, then tighten the belt and the belt will distribute the oil where it needs to go. As far as the walk belt, just make sure that is stays in the center of the walk board. Now your front roller and drive belt. The roller does not get serviced, it has perminently sealed bearings. The drive belt usually lasts for many years, if you remove the motor hood and see alot of black dust, it will be the belt. At that point you need to see why it is comming apart/rubbing. After you determine that, you would want to replace it.
The slipping you are describing could be the drive belt slipping on the front roller or the drive pully on the front roller. To find out you need to remove the motor hood nad get on it and look. What you will be watching is the drive belt as it goes from the drive motor to the drive pully. When you try to stop the walk belt you will either stop the drive belt or stop the walk belt. If you stop both, the drive belt is at fault, if the motor keeps turning. If you stop the motor, the motor or the controller is bad. If you stop the walkbelt and not the drivebelt you have a bad drive pully on the front roller, and need to replace the front roller. When you do this you need to remove the drive belt, this is a ggod time to replace it.
Hope this helps, rate my solution if it helped you. Thanks, Matt
Jan 09, 2011 | Proform 495pi Treadmill Frontdrive Roller...
Belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Feb 20, 2010 | Proform CrossTrainer Treadmill
The drum won't move and it make like a buzzing sound.
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley
Jan 21, 2010 | Kenmore Washing Machines
Agitotor not spinning during wash cycle M/N: LSR8244EQ1 Machine less than 10yrs. old, good shape
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Jan 02, 2010 | Whirlpool Washing Machines
How to remove and replace a motor belt on proform
Hello there. To replace the drive belt (motor belt) follow this procedure.
1)Remove power to the machine
2)remove the hood cover (3 screws on the rear of the cover)
3) loosen the adjusting bolts for the walk belt located on the opposite end of the walk belt from the hood assembly. Loosen the adjusting bolts 10 full revolutions. This will loosen the walk belt.
4) You should then walk the drive belt off of the front roller/pulley assembly by pushing the belt to one side while turning the motor. If you are nable to do this you will need to loosen the 2 bolts holding the drive motor in place.
5) After removing the drive belt you can then slide the drive roller to the side out of the frame and it will slide out the other side of the bracket. This will allow the belt to be removed from the front roller and be replaced.
If you had to loosen the bolts holding the motor you will need to retension the drive belt by pulling the drive motor back while tightening the bolts. This will require another person to help tension while you tighten the bolts.
You can then retension the walk belt using the adjusting bolts and retightening them 10 revolutions.
Good Luck Tim
Dec 13, 2009 | Exercise & Fitness
The rollers are not turning. It is not an electrical problem because water shoots from the top.
There are two motors usedi n an Aquabot. The pump motor is separate from the drive motor, and the drive motor acts to drive the wheel tubes by means of a belt drive system. If the drive motor is working ( lookiing at the unit under power, the drive motor shaft which an be seen on either side of the unit is turning) ,t
Then you have a dive belt problem, solved by replacing the drive belts. If you happen to be in or near Phoenix, Arizona, I can help you replace the belts. If not, the belts can be purchased fairly inexpensively and are not hard to replace. If the drive motor is shot, the only answer is to contact an authorized repair center. S. Christian dansker 01@ msn.com
Aug 14, 2009 | Aquabot Turbo T
Exercise & Fitness Logo
135 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
