Question about HP Pavilion a420n PC Desktop
A420n broke the button to turn it on needs replaced
  • joecoolvette
    joecoolvette May 11, 2010
    The actual plastic Power On button, or the little power on switch that is behind that button? Before you remove the Front Panel to access, and remove the Power On button, and the switch, make yourself some notes, and a little drawing, as to where on the motherboard those wires go. They connect to pins that stick up out of the Front Panel header, on the motherboard. (Connection on a motherboard is referred to as a header. The plastic part of your computer in the front is a Front Panel) A digital camera plus good lighting could come in handy. Here's that switch,http://www.directron.com/atxswitch.html
    Problem Solver:
  • 5 Answers
When mine broke all i did was disconnect the two wires from the button, solder to a small toggle switch,drill a hole in the case and fit toggle switch,works fine
Posted on Feb 07, 2010
I am unable to install VGA drivers in my hp pavilion a420n. Please help! I've downloaded all drivers ...
if drivers are missing or not suitable....??
den find the mother board No. and search it on Google and download and install it..
Apr 04, 2014 | HP Pavilion a420n PC Desktop
I CANT RESTORE MY HP PAVILION A420N. WHEN I TRY IT SAYS I NEED A RESTORE DISK AND EVERYTHING SHOULD BE ON MY D DRIVE. I HAVE RESTORED BEFORE WITHOUT ANY PROBLEM BUT SURE ARE HAVING THEM NOW. WHAT CAN I DO?
i dont claim to be any expert, in fact far from it. our hp paillion came with a restore disc that restores all programs/software that were origionally in the comp and also the extra optional stuff u could download at setup maybe u can get a copy of one from somewhere when ours crashed it was the only thing that got us up n running again
May 08, 2012 | HP Pavilion a420n PC Desktop
My hp pavillion a420n keeps shuting off and turning itself on every once and a while. Also othe flash keeps crashing and programs keep failing. Any clue what it may be telling me?????
Hardware failure - the voltage to the processor is unstable because either the PSU or the rectifiers on the motherboard have aged. Open the case and look at the motherboard - if some of the capacitors on it are bloated then you will have either to replace them or the entire board. If the capacitors are fine in there then the fault is in the PSU - you can get a new one for less than $20 at every pc shop.
Jun 03, 2011 | HP Pavilion a420n PC Desktop
Green light flashing at the back &the power will not come on
Hewllo. There is an error with your power supply. You need to get it tested and/or replaced.
Thank you.
Nov 04, 2009 | HP Pavilion a420n PC Desktop
My HP a420n won't start after replacing cd-rw drive
Please try to remove all the connections from your computer and also connections inside the motherboard, the power cord for your hard drives and also the power cord from the power supply to your motherboard.After that, remove the memory and clean the pin by using an eraser of the pencil. And then insert again the memory stick and connect all the connections from the power supply to motherboard and everything. Lastly reset your bios and put it back to normal again. Hope this would help. Thanks..
Oct 22, 2009 | Computers & Internet
Hp Pavillion a420n blinking light
Hello.
Is the computer still its power ? if the pc has its power then try to switch on without the memory. if the system beeps means that the mainboard and processor is good. However, if the pc has no power at all then first check the power supply.tell me what happen i give you more troubleshooting.
Mar 25, 2008 | HP Pavilion a420n PC Desktop
Hello!
Is the pc has blinking power in it. or do your hear any beeping sounds? but anyway you can do check your PC. unplug the pc and open the system. remove and clean the memory and insert it again. and fix all connection inside the pc maybe some cable lessen. after that test the pc. and then tell me what happen i will give you more solution in it. melnavz
HP Pavilion a420n PC Desktop Logo
148 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
