Question about Kenmore 24 in. 15689 Built-in Dishwasher
Our kenmore dishwasher has no lights on in the front and it is not turning on it still has water in it from the last load
Our dishwasher door will not stay latched so it can complete the wash cycles.
Posted on May 09, 2010
  • 572 Answers
These have a fuse behind the panel
Posted on Feb 07, 2010
3 Suggested Answers
futureloginn
  • 734 Answers
SOURCE: KENMORE DISHWASHER WATER DOESN'T SPRAY.
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely
replace it. It's usually located behind the lower access panel on the left or right side. It's the device
with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two
wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor."
Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills
the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised
position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Dec 12, 2008
  • 40 Answers
SOURCE: Kenmore Dishwasher, 66517029401. Lights on control
are you sure the breaker that runs it didn't trip?
Posted on Feb 28, 2011
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore 18 in. dishwasher is not spraying water and the sprayer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 25, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore portable dishwasher not working
if you can get underneath it try spinning the motor manually (after turning off the circuit breaker). sometimes the motors on dishwashers get jammed.
May 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher wont fill up but can hear the motor....
dishwasher? could be the fill valve bad. or the float switch is stuck in the up position.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
NO Clean Dishes
dear sir this may be the problem  Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Caution: Because the dishwasher is connected to both the plumbing system and the electrical system, you must consider both systems when working on this appliance. Before doing any work on the dishwasher, make sure the unit is unplugged or the power to the unit is turned off, and remove the fuse or trip the circuit breaker that controls the circuit at the main entrance panel or at a separate panel. Shut off the water supply to the dishwasher at the shutoff in the basement or crawl space under the kitchen.how-to-repair-a-dishwasher-1.jpg
thanks..................................
Sep 11, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher "sensing" light
the sensing light and buzzing are normal let it do that on its on then let me know what happens its a soil sensing light and is supposed to run a cycle on its own to clear it but lets see .we will go from there ok
Jan 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore dishwasher model 63991 (10yrs old)
If the display works, but the machine doesn't fill, wash, or pump out, the control board is the only component that could cause all these symptoms.
Aug 26, 2007 | Kenmore 24 in. 16259 / 16254 / 16252...
Kenmore 24 in. 15689 Built-in Dishwasher Logo
173 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
