Trying to hook up an extension wire to the remote sensor> Want to know if i can do that. It a Toshiba SD-5000 dvd player. My idea is that my dvd player is in the closet and the wires are going thru the wall to the tv(the tv is a wall mount)in the bedroom. So when Im in bed I wanna be able to use the remote while in the bed. If anyone can figure this out let me know.Thx
  • 12,061 Answers
Ok you need an Ired extender kit. Like this one in the link. I think that will give you the idea. I would hunt on Ebay.
http://www.tradetech.co.nz/Parts/IR+Extender+Kit.html
Posted on Feb 07, 2010
Does a toshiba sd-6000 dvd vedio player have remote capability
I have not seen Toshiba DVD player, but you can verify if it has the remote sensor on the player with small red jewel lamp.
May 12, 2014 | Cyberhome CH-DVD 300 DVD Player
Toshiba SD-5000 DVD Player - disc tray stuck
Try first turning off the player and turn it back on and eject it using the eject button on the unit and also try to eject it using the remote.. IF still wont eject this can be a mechanical function on the ejecting part of the unit that you may need to open the unit and check for that..
Hope that helps.........
Aug 07, 2008 | Toshiba SD-5000
How do I turn on the closed captioning on my Toshiba SD 5000 DVD player
What happens when you press the "Subtitle" button on the DVD remote control several times after you insert a subtitle-enabled DVD?
If you don't have the manual handy for your DVD player, I've added a link for the Toshiba SD-5000KU. The Subtitle button is described on page 13, but the description only tells how to turn subtitles on. However if the programming is typical, pressing the button repeatedly cycles through a series of language options with "Off" at the beginning or end of the list. Otherwise, it may be programmed to enter a subtitle menu that you navigate with the direction arrows (page 14).
Toshiba SD 5000KU Owner Manual
Jul 03, 2017 | Toshiba SD-5000
I own a Toshiba SD-1200 DVD player but have lost the remote control. Without the remote control it is useless; you cannot play DVDs on it because there's no "Enter" button on the DVD player...
looked around for you couldn't find a new one but i did find one at this link,
http://cgi.ebay.com/Original-TOSHIBA-DVD-Remote-Control-SE-R0030-SD-1200-/400098986865?pt=LH_DefaultDomain_0&hash=item5d27c20b71
Jan 23, 2011 | Toshiba SD-1200 DVD Player
Toshiba sd-5000 just not playing. all HDMI cables are properly plugged in. Accidentally push a "strange button on the remote and the DVD player just topped working. The LCD shows that it is working, but my...
I got the same problem today. I thought it was a connection on HDMI cable problem. I tried many different options to solve it but nothing was working. After I read your post I realized that my 2 y old boy was playing with the remote before it happened. So I found on menu in DVD player option - default setting- and I pressed it - and bingo - it's working. I used cinch cables instead HDMI while I was fixing - just in case you cannot get the menu screen on tv - good luck
Jan 20, 2010 | Toshiba SD-5000
Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
Aug 31, 2009 | Toshiba SD-5000
Trying to program comcast remote to work with my toshiba SD-V290. Need the remote code???
http://www.comcast.com/corporate/customers/customer_support/remotes.html go there and click the remote your using and then find the brand and get the code
Jul 12, 2009 | Toshiba SD-V296 DVD Player/VCR
Unlock region code for Toshiba SD-5000
what make of dvd player do you have?
make and model
Jan 18, 2008 | Toshiba SD-5000
No picture, but sound
I had the same problem and I managed to solve it. It was because the HDMI was set to 1080i and my TV isn't HD. Default HDMI is 480p. You can check your current HDMI setting on the front panel of your DVD. There should be a button with the words "HDMI select". Next to it there should be 3 values. If the current one (a green light shows which one is selected) is not 480p, change it. To change it, make sure your sd-5000 is on, but not reading a DVD. The press the "HDMI select" button on the front panel until the selected one is 480p. This worked for me.
(I had the same same problem without the reading slowly part. On one TV, the sound and video weren't working, and only the video wasn't working on another TV)
Hope it helps.
Dec 28, 2007 | Toshiba SD-5000
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
