Question about Rheem Paloma Tankless Water Heaters PTG-74PVN Tankless RTG-74PVN
Paloma tankless water heater is reading 14 - 0on the display what does that mean
    Problem Solver:
  • 13 Answers
There is a piece of clear plastic film wraped around the heat exchanger. Conductive material (black) is coated on that film. In case of overheating, the film melts, break the circuit and the heater stops. That's how it works, in theory. I had the same problem and had to remove the heat exchanger to inspect the film on the back side. It's a pain in the @#$%, especially found no problem with the film itself. This is what you should do: Find and disconnect connector U in the center of the board with 2 tiny white wires. Measure resistance between those 2 wires, should be 50K~100K. If it's open, either the film is damaged or, in my case, the connector on the film is bad (on the right side of the heat exchanger). Since no other tankless maker uses this protection scheme, I don't think it's doing much. My solution is to fool the controller with a 100K ohm resistor across the 2 white wires. If you're not comfortable with my micky mouse solution, replace the film.
Posted on Feb 12, 2010
    New Friend:
I am certain that the 100 ohm resistor would work perfectly, but since I wanted to take a hot shower tonight, I simply used the half of the film that was remaining by Drilling a screw through it and vent racing the Black Ink about halfway through and drilling another screw through it. A range of 50-500 ohms is significant so even a small piece of remaining film should provide the necessary resistance.
Posted on Apr 26, 2016
I followed these already posted directions, found the thermal film melted and could not really trace the wires from the board to the film. I went straight to the film connections pulled the wires from it and spliced in the 100k,1/4 Watt R between the two white wires...... and i am back in hot water. Gotta love the net!
Posted on May 06, 2012
Hi There,
i placed the 100k resistor but error code still show 14-0 and still not working
please advise what should i do now.
Thanks
Posted on Jul 22, 2011
Hi Gizmonix I did your 100 ohm resistor bypass trick to get around a damaged plastic film and the darn tank still flashes 14 -0 Any other ideas what I could check to fix this?
Posted on Feb 22, 2010
  • commodore128 Feb 22, 2010
    Sorry, After putting on my glasses (cough,cough) I realized there was a k on the end of that resistor value. I found a 100k resistor, put it inline and BAM! The water heater works again and its nice and clean now too. Thanks a Million gizmonix Now where can I order a new plastic film fuse?
I have a Paloma PTG-74PVN-1 high volume tankless water heater installed in 2007. Recently, I am having hot water temperature problem, no error code is displayed, but it can not heat the hot water beyoun...
Even though you are not getting an error code, there are may be some diagnostics in the controller that can identify whether it's an electronic (controller/sensor) or a heat exchanger issue. I would contact Rheem tier-2 support.
Jul 01, 2014 | Rheem Paloma Tankless Water Heaters...
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
Oct 19, 2012 | Rheem Paloma Tankless Water Heaters...
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Rheem-Tankless-Fault-codes.pdf
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
Paloma tankless ptg42 water heater error code c4/13
4 error message, the 4th (last) error code is #13, not enough oxygen.
Check the location of the heater, if it is fine the ODS sensor (actually is a thermal couple) is bad.
Dec 25, 2009 | Rheem Paloma Tankless Water Heaters...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
I have a paloma ptg-74pvn and the digital temp. display keeps shu
How reliable is your AC? With the digital r/c connected, every time the heater recovers from power outage it's in the OFF default state. If you can not fix the power issue, disconnect the remote control. The w/h will recover in the ON state.
Nov 13, 2009 | Rheem Paloma Tankless Water Heaters...
Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
May 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma  Tankless Water Heaters PTG-74PVN  Tankless RTG-74PVN Logo
534 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
