Question about FrancisFrancis! X1 Espresso Machine
Francis! Francis! X1 problems
We bought a Francis! Francis! 6-7 years ago and have never had a problem with it. Now, however we are thinking the pump may be going bad and don't know what to do. The pump definitely seems to be louder and when using a double portafilter, one side pours while the other side only drips. Also, it is not warming up as quickly. Today the pump light was blinking intermittenly and I couldn't get the temp. above 90 degrees.
5 Suggested Answers
jmgldsmth
  • 2005 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
  • 1089 Answers
SOURCE: drip drawer for white FF X1
HI
Try Illy.com
877-469-4559
They should be able to point you in the right direction
Posted on Nov 24, 2009
  • 1089 Answers
SOURCE: francis francis X1---the steam nozzles won't work,
HI Unscrew the chrome tip from the wand. Then check the wand tube for a plug. Insert a paper clip into the wand tip to see if there is a restriction.
Posted on Feb 07, 2010
  • 3 Answers
SOURCE: Hello I have a Francis Francis X1 and the twin
Is this what you looking for?
http://www.craystoneshop.co.uk/acatalog/FrancisFrancis_Spare_Parts.html
or this?
http://www.craystoneshop.co.uk/acatalog/FrancisFrancis__Coffee_Handles.html
Succes, TonB
Posted on Feb 28, 2011
"francis francis" x1 blocked - Fix Suggestions?
You can tell if the pump is working by the noise it makes. Mine got blocked with scale and I took it apart and cleaned out the boiler. It's possible; the boiler is bolted together with standard bolts (metric size). If you've got the interest the Francis Francis is easy to service; you will find a way into each part of it and clean it, and if you do it will work like new.
Jun 22, 2014 | FrancisFrancis! Coffee Makers & Espresso...
Í have a francis francis X1 for 3 years now.
Hi
There are 4 nuts that hold the chrome head on. They are either 7mm or 8mm nuts. Loosen then and the head should twist out.
Nov 23, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 pump replacement.
http://www.craystone.com/francis/francisfrancisfaq.html
for spares Espresso Parts, Tel: 0870 3851531
Oct 20, 2009 | FrancisFrancis! X1 - Stainless Steel...
No steam
You may have a clog in one of the hoses. Otherwise pump may be clogged. Or faulty heater. Is it hot?
Aug 28, 2009 | FrancisFrancis! X1 Espresso Machine
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis! x1 leaking
Well, to state the obvious, you should call Francis! Francis! at 1-877-854-4141 and ship it to them for repair. It's unlikely you can perform a fix yourself. Have you tried opening the machine up? I got PDFs of diagrams and part lists, which I obtained by calling them at the number quoted above. Good luck! Stephen
Dec 13, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 Espresso Machine Logo
120 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
