Question about Video Game Consoles & Games
How to hookup wireless internet - Video Game Consoles & Games
  • 12,061 Answers
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Posted on Feb 07, 2010
Acer AX1920-UR20P computer will not connect with Internet, I have tried wireless and ethernet connections.
is modem in bridge mode? sounds like you try wireless first. the router would then do the dhcp to get you on the net I would hook modem to router to tower. you may also want to power cycle them.
Aug 11, 2015 | Acer Computers & Internet
Hookup internet wireless
Please check your system specs out very carefully. This particular system does not support nor include any wireless capabilities. To use the internet connectivity, you must run a CAT-5 Network cable from your router, to the network port on the back of the console!
http://images.owneriq.net/download/images/7/73fb106c-28a9-43af-83b1-656b4b895d5e-000001.png
Sep 07, 2011 | RCA RTB1100 Theater System
My sister is visiting and when we tried to put her laptop on my internet hookup the message was displayed stating that my internet connection through comcast was unsecured. What do I do to correct this...
its letting you know that your wireless network is open and not secured. she just needs to acknowledge it and she will be able to browse the internet but it is not secured.
if you want to secure your wireless network you will need to configure it by opening internet explorer
browse to http://192.168.1.1
the default login is blank and the password is admin
click on wireless
click on wireless security and choose wpa personal
enter a passphase which you will use to join your wireless network securely on any wireless device.
your sister will need to rejoin the network once you do this and you will need to rejoin any other wireless device to join your secured wireless network.
Apr 03, 2011 | Linksys Wireless-G WRT54G Router
Can't get online to play this new PS3. The console is hooked up to the TV & Belkin Wireless router. The internet, computer and phone line are in a different room and can't reach to hookup. AT&T is...
There should be no HDMI cable to router. In any situation.
Try the following:
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and choose the appropriate settings. (What's highlighted is going to be the best option, continue to hit the right button on the analog to go through the stages.)
Be sure to choose "Wireless" when configuring the settings if you are using wi fi for connectivity.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
What connections are needed to hookup the ps3 to the internet?
You can either hook up your PS3 through hard wire using an ethernet cable plugged into your PS3 and your modem or wireless since the PS3 has a built in wi - fi adapter for the wireless network in range.
May 12, 2010 | Sony Playstation 3 (PS3) Console
Have a computer with a new lynksis wireless-b router. i am running windows xp but dont have internet to the computer (minus the wireless) how can I install a driver with no cd or internet?
If you do not have the drivers on media, then you will have to obtain them first. Can you temporarily hookup wired and get them downloaded? or use a usb flash drive on another computer to access and download the drivers...
Apr 14, 2010 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
How do we get wireless hookup to PC in rural area no cable or DSL
You will have to use a wireless cell phone type of modem. Some hi end cell phones like, blackberry's and some blackjack's have this capibility, to be used as a computer internet modem, see your local cell phone co. This service will be a bit expensive.
Aug 31, 2009 | Compaq Presario 5000 PC Desktop
Wireless internet hookup
Any wireless pc card will work.
Jan 20, 2009 | Panasonic Toughbook 47 Notebook
Internet hookup
Hello, I see your wanting play online, Your xbox needs either a wireless lan adapter if wireless internet available, if not then yes you will need a internet cable, just be careful on which cable you buy, cause not all internet cables work with the X-box systems. Hope this helps and we look forward to hearing back from you.
Jan 16, 2009 | Microsoft Xbox 360 Console
How do I hookup ps3 using wireless laptop
I'm assuming here that you mean that you want to connect your ps3 to the internet through a windows laptop connected to the internet wirelessly, correct me if i'm wrong...
  1. connect an ethernet cable into your ps3 and the other end into your laptop
  2. Connect to the internet on your laptop
  3. go to control panel on the laptop
  4. go to network connections
  5. select "Local area connetion" and "wireless network connection"
  6. right click on one of them while they're selected
  7. click bridge connections
your ps3 should now act as if it was directly connected to the internet
Feb 16, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
237 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
