Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Heater will light but when gas is injected stays lit for 5 seconds then goes out
    Guru:
  • 415 Answers
I would start with the flame sensing rod. There is a small metal rod approx 2 inches long with the diameter of a wire coat hanger.It has one wire attached to it which goes to the gas control board. It is mounted in front of one of the burners (often the burner furthest from the ignitor). This sensor sometimes develops a light coating that works like an insulator which will prevent it from sending the proper signal to the board to allow the gas valve to remain lit. In this case, the solution is simple: take a scotchbrite pad and lightly rub the flame sensing rod. This will remove the coating and allow for a proper signal to the board. Take care not to break the ceramic insulator, dislodge one of the burners, or to mistake the Hot Surface Ignitor for the flame sensing rod. The Hot Surface ignitor is the part that glows red and ignites the gas when the valve opens. It is extremely delicate. It has two wires (not one) and looks nothing like a single rod as I described the flame sensor. However, it too is mounted in front of a burner.
I hope you find this helpful. Good Luck! :-)
Posted on Feb 07, 2010
My gas Dearborn model#drc40mc pilot light stays lit.when I turn to on position and heater comes on , it burns high , even on low number setting, then after few seconds goes out taking pilot out also
clean/replace the flame sensor. Your heater doesn't recognize that it has lit and continues to try and light the gas. when the sensor doesn't tell the 'brain' it lit? it shuts down the gas for safety reasons.
Oct 19, 2014 | Heating & Cooling
Richmond power vent will not stay lit, the bunrer will lit than after about 5-10 min. it goes and tries to relite and than goes into lock down. after it about 5 min. you can reset it and it will do the...
Richmond-Ruud-Rheem
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
It sounds like you've read the manual.
And cleaned the burner parts according to manual.
You replaced thermal reset, but system is still tripping, so either the gas valve and tubing are bad, the thermocouple is bad, or there is a problem with gas pressure, or gas line.
Post question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Apr 08, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Water Heater Burner Won't Stay Lit
have you tryed the pressures switch try jumping it out and see if it lights up
Jan 01, 2010 | Reliance 43614 Heater
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
MY HYWOOD h SERIES POOL HEATER DOES NOT LIGHT. IT
are you sure the code isnt FO , which would indicate flame sensor failure.usually can be solved by removing and cleaning fl sensor with fine emory cloth.since htr is calling for heat ,pressure switch does not need adjusting
Jul 04, 2009 | Hayward H-Series 200k BTU Millivolt Heater...
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Heater goes out after 10 to 30 seconds.
sounds like a blocked pilot when you turn on the main gas takes the gas away from the pilot and goes out
Nov 08, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
87 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
