Question about Acer AL2223W 22" LCD Monitor
Myscreen is too bright is it possible to change this?
Can't figure out how to use buttons on monitor
  • Acer Master
  • 12,061 Answers
You use the buttons. You press the middle button, if 3, and a menu will appear, navigate by repeated "presses" on the button, this will advance it through the items, then "Select" with the middle button, & use the buttons either side to go Up & Down, + or - in value, with the middle button as the "Select" or "End".
Posted on Feb 07, 2010
Testimonial: "thanks for your help"
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
Change brightness
The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
BuddyMc
Aug 07, 2013 | Dell E178FP 17 inch LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
I don't understand anything about changing the display settings on my Acer p215h monitor I push the buttons but can't figure out what to do
umm...usually if it is a desk top there will be buttons either on the side, front or back or even the top, one looks like a sun and another looks like a square thats normally half white and half black. they are your brightness and contrast...push either end of the buttons to adjust more bright or less bright, more contrast or less contrast.
Sep 16, 2012 | Acer P215H LCD Monitor
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Brightness!
mcdevito75 here, You can try this, 1 of the buttons should say AUTO presss this button and the monitor will automatically adjust, and Or press the MENU button and see if there"s a brightness feature, I believe there is, you can use the little arrows on your monitor within the MENU options. First try the AUTO.
Jul 04, 2010 | KDS Radius RAD-7c 17" Flat Panel LCD...
My 19" Princeton flat panel monitor is "washed-out" looking. It is very light, I can hardly see the characters, letters, etc. on the screen. I don't know how to adjust this as there are two buttons on...
reset the brightness and contrast if something has causedmthem ti go uo. somewhere around 50-70% seems right, but set on a screen you know what should look like
Jun 08, 2009 | Princeton Digital LCD1510 15" Flat Panel...
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Jun 05, 2008 | HP Pavilion dv1000 Notebook
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
Acer AL2223W 22" LCD Monitor Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
