Question about Whirlpool Duet GHW9150P Front Load Washer
My washer would not wash it is just one year old . it is showing 1nb it is draiining but not spinning
  • 32 Answers
ONE YEAR OLD..CALL YOUR SERVICE CENTER FOR YOUR APPLIANCE,IF IT IS JUST ONE YEAR OLD,ITS UNDER WARRANTY AND YOU DO NOT NEED TO DO ANYTHING OR YOU WILL VOID YOUR WARRANTY.
IF NOT SURE WHO TO CALL START WHERE YOU BOUGHT THE APPLIANCE..
LACUZ12.
Posted on Feb 07, 2010
Lg top load washer 1 year old, vibrates violently during spin. Checked an adjusted level, no help.
they have springs and shock absorbers in the machine to help stabilize the load when spinning. since the washer is so new, i would guess one or the other has just come loose. take top off and check. online videos will show you how
Feb 24, 2016 | LG WT4801CW Top Load Washers
Washer won't spin. 2 years old.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 07, 2011 | Kitchen Ranges
The tub won't drain and it spins very slowly. I've also noticed, over the last couple years, some oil/rust spots on my clothes. It is a top loading washer that is over 20 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 13, 2010 | Amana Washing Machines
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Transmission tries to spin... belt spins and the rubber smell comes. Should I get a new transmission? The washing machinge is only three years old. Thanks... Honey Do Man
Check the pump bearing. They lock up frequently on this type machine.remove the belt and turn the pump. It should be easy to turn with no visable bearing parts showing.
21001906 is the part number.
May 15, 2009 | Maytag PAV2300 Top Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
